March 30, 2009 at 2:47 pm #139743
I have been trying to get my site listed on google and was advised to look at the SEO Settings in the Joomla global configuration.
I set all three options to “yes” (and made the necessary changes to .htaccess) and everything seems to be working well, except…
One of my pages no longer works and I get a HTTP 500 Internal Server Error.
The only page I am having this problem with is:
http://www.alovelypint.com/offers.html
The homepage and all the other pages seem to be fine…
Any advice would be gratefully received.
- 1334 times in 848 posts
March 30, 2009 at 2:55 pm #299066Did you try cleaning the Joomla cache?? Is there any other SEF url component or plugin you are using along with your joomla site? Try cleaning your cache and let us know.
March 30, 2009 at 3:01 pm #299067There isn’t anything in the cache. I just checked both “Site” and “Administrator”.
I am not using any other SEF plugins.
Thanks for your time.
March 30, 2009 at 3:04 pm #299068May be if you are comfortable, you can PM the backend login details, i would like to have a look and try to find the problem. But Remember i am NOT Joomlart Official Support Member.
If one works, all should work technically.
1 user says Thank You to Arvind Chauhan for this useful post
March 30, 2009 at 3:08 pm #299069Thanks for your help – I have PMd the details to you. 🙂
scotty Friendscotty
- March 2008
- 827 times in 595 posts
March 30, 2009 at 4:19 pm #299075Most likely caused by a 3rd party component or mod you have published to the ‘offers’ page. Many 3rd party extensions are not compatible with SEF urls.
March 30, 2009 at 4:30 pm #299081Thanks scotty, Checked that too, it just wont work, the offers page is section blog layout, with only one article in it. it works without sef. Tried adding the same article as uncategorized and gave a article layout link, it just wont mend….
scotty Friendscotty
- March 2008
March 30, 2009 at 4:40 pm #299084the title was “this week’s offers” i tried with changing it to “this week offer” and even just “offers” . No result.
the host is slow and .htaccess is default joomla but with additional line of top “SetEnv DEFAULT_PHP_VERSION 5” , owner says it is required otherwise the forums wont work with sef.
checked the php info from joomla backend its 5.2. something.
anything i missed to check?
scotty Friendscotty
- March 2008
March 30, 2009 at 4:45 pm #299087You got a joomla default link to the page?
scotty Friendscotty
- March 2008
March 30, 2009 at 4:46 pm #299088There’s no restricted access level or anything for that page I presume?
March 30, 2009 at 4:50 pm #299089no, it’s public access
this is doing my head in tbf… i have renamed a section and category to “Beer Offers” and i get the same problem
the one I renamed was called “wallpaper” and it worked just fine!!!
:confused:
maybe Joomla SEF doesn’t like the words “beer” and “offer” together…
scotty Friendscotty
- March 2008
March 30, 2009 at 4:53 pm #299090Can you open the menu item ‘Beer Offers’ and post what it says in the ‘link’ box please?
March 30, 2009 at 4:55 pm #299091index.php?option=com_content&view=article&id=69
scotty Friendscotty
- March 2008
March 30, 2009 at 4:58 pm #299093Have you tried it without SEF? Doesn’t seem to work.
http://www.alovelypint.com/index.php?option=com_content&view=article&id=69 – not working
http://www.alovelypint.com/index.php?option=com_content&view=article&id=67 – working
This topic contains 24 replies, has 3 voices, and was last updated by scotty 15 years, 9 months ago.
