  • mexx uk Friend
    #142117
    I’m trying to put a separator in the main menu at the top of the kulanite template. When I do however, it causes the entire top menu to disappear!
    Any ideas what I’m doing wrong? If I unpublish the separators the main top menu re-appears.
    Trying to get this:
    Separator Main
    |_separator2
    |_Menu Item 1
    |_Menu Item 2 etc…
    nguyenhuu quang Friend
    #308886
    what your menu styles: moomenu or another.
    pls open your template check param and you can see your menu styles
    mexx uk Friend
    #308919
    Set to moo menu, however, it still does the same no matter what menu type I choose…
    #309037
    could you send Live site, i can check it foryou
    thanks
    mexx uk Friend
    #309046
    Details sent in PM…
This topic contains 5 replies, has 2 voices, and was last updated by  mexx uk 15 years, 6 months ago.
