  • holahola84 Friend
    #118624
    Hi, I would like to include Simple Machine Forum in my website, and on the forum page, I want my header, logo, horizontal navigation etc. to remains on the page (i.e. Like this page).
    To do this I need to seperated header.php, but for the templates here the header is included in the index.php, can any1 roughly teach me how can I seperate index.php into “header” and “body”?
    birdoasis Friend
    #214494
    Use whatever editer you want and copy the section of the header.php file that is under the header comments, and place it in the header.php file of the forum.
    Now you may also have issues with css, so check the <div ags to see if the forum has the same titled <div. For instance, if it has “<div #body” and the css also has the “<div #body” tags, then you may be able to use the template_css.css file for the forum, but I doubt that it will have all the tags needed. So what I would suggest is this.
    In the header.php file for the fourm change the css file listed as required and replace it with the template.css. The body of the forum should keep the original css file and you will avoid some irritating issues.
    holahola84 Friend
    #214502
    Thx for the reply, however for the time being I have decided to use joomlaboard instead. I tried seperating the header apart but seems to have a number of issues bcos of the “mos” stuff which is not recognize by smf, apart from that there is still other issues. But still thx alot for ur help 🙂
    ErikThorsen Friend
    #214555
    I was just going to recommend Joomlaboard but seems like I don’t have to do this now. 🙂 I find it very useful ( and it is translated to my language which also helps )
    holahola84 Friend
    #214558
    Yea, at first I was not quite satisfied with joomlaboard. But after abit of hacking and downloading of different icon sets, it works fine and looks pretty good now! :laugh:
This topic contains 5 replies, has 3 voices, and was last updated by  holahola84 17 years, 11 months ago.
