  • jclivingstone Friend
    #143648
    Ok. I managed to rescue my lost data. However I get the same problem on frontpage blog layouts – everything else works a treat.
    I recently installed Sulfur on my site http://www.gadgetgrotto.tv.
    After installing it I realised that column left and right were not aligning properly. I read through a couple unanswered threads about it where you suggested using the quickstart install.
    So I did… I now find that all of my content has gone missing and I cant seem to copy the SQL data across into the new jos_ files.
    Help. There’s a years load of data that I need to recover.
    Phill Moderator
    #315110
    Did you backup your tables before installing the quickstart?
    bennitos Friend
    #315119
    You said that you solved the biggest part, i just had a look at the site and im not sure what is left to be fixed.
    Can you be more clear about what problem remains?
    mj1256 Friend
    #315128
    if you did the quickstart, did you create a new database, if so, all of your old data will still be in the original site db, all you need to do is go to your global config, i think on the server tab, and point tpt the old db
    you should always backup your site before making any changes to it, I recommend joomlapack
    #315159
    Hi Mark
    You’re absolutely right. I should know better.
    The problem with the site right now is that when I use the frontpage blog for the homepage the right and left columns align underneath the main body column.
    This problem only occurs when you use the frontpage blog. A normal category or section blog or article view doesn’t have this problem.
    Is there a suffix that’s supposed to be used for the frontpage blog?
    I’ve set the frontpage blog up as home so you will see what I mean.
    Thanks for your help.
    Jim…
This topic contains 5 replies, has 4 voices, and was last updated by  jclivingstone 15 years, 4 months ago.
