  • fdr77 Friend
    #168556
    The search in Ja-teline-iV don’t work… is empty page… with ja-purity work fine
    Help me
    1. 1w
    2. 2w
    3. search-purity
    Phill Moderator
    #412700
    First thing to try us please make sure the JAT3 plugin and the Template are updated to the latest release. Please use the JA Extensions manager to do this.
    fdr77 Friend
    #412707
    Teline_IV 1.25 jat3 1.2.6 because 1.2.7 and 1.2.8 give me a problem in the menu
    fdr77 Friend
    #412749
    the error only occurs if I do the search from a main menu item…if ido search from sub-menu work fine
    example
    if search from mod_search(search position) in this page
    http://www.discusrewind.net/articoli/sezioni/conosciamo-il-discus.html
    work fine
    if search from mod_search(search position)in this page
    don’t work
    fdr77 Friend
    #412754
    I understand the problem.
    In the .htaccess I put
    # Redirect /index.php to / - will also clear /index.php/something to /something
    RewriteCond %{THE_REQUEST} ^+ /index.php(/[^ ]*)? HTTP/
    RewriteRule ^index.php(/(.*))?$ /$2 [R=301,L]
    and this creates the problem.
    How can I keep that code without having the problem?
    HeR0 Friend
    #413851
    hi, fdr77, i’m checked your site and do not seen error. I try access fpt your hosting but i have not permission view and edit .htaccess file. Did you delete this file?
    fdr77 Friend
    #413853
    httpdocs/.htaccess
    i don’t have delete the file
    khoand Friend
    #413879
    I tested it on your website. It works normally.
    fdr77 Friend
    #413886
    Yes, but only if I remove the redirect ….without redirect and I have many duplicate titles.
    each page is found with and without index.php….also many title duplicated in web master tool
    Phill Moderator
    #413895
    Khoand, the devs are dealing with it. No need to put your efforts in.
    fdr77,
    Can you PM Hung Phung some working ftp details and put in place your redirect first so the devs can investigate for you.
    fdr77 Friend
    #413926
    send details
This topic contains 11 replies, has 4 voices, and was last updated by  fdr77 13 years, 3 months ago.
