  • sushismb Friend
    #164829
    I’ve encountered some minor and major problems with IE8and9 using this template.
    IE8
    There shouldn’t be a space on top above the menu. But in IE8, there is a white space.
    Both IE8 and IE9
    The menu bar becomes a 2 liner. I’m not sure if this is caused by my customization, however, I don’t see this happening on Firefox.
    IE9
    I use ja_news_fp. When using headline_fp as headline style and when logged in on the front page, the headline article DISAPPEARS. The article show without any problem when NOT logged in. Also, when I change the headline style, the article will show.
    I hope this could be fixed by JA immediately.
    Thank you very much in advance!
    kshama_k Friend
    #394913
    hi
    I tried to access your admin and ftp but error occurs ,please send me your correct admin access by editing your post to update access fields.
    i saw a site in ie8 i think there is an height problem just change in tagcloud.css as
    .clearfix{
    height:0px;
    sushismb Friend
    #395288
    Hello kshama_k,
    Sorry for the wrong info. I edited the info just now.
    I hope you could help me out. By the way, the problem with IE9 is solved. It’s just that it takes longer to load.
    With your suggestion with tagcloud.css, what is this related with?
    Thanks!
    kshama_k Friend
    #395462
    hi
    you have a problem with white spacing on top in IE8,
    so you can make changes in tagcloud.css. as shown above.
    sushismb Friend
    #395632
    Hello kshama_k,
    Thank you for your reply.
    Where can I find this tagcloud.css?
    Also, how about the issue on the two liner thing?
    Thanks!
    kshama_k Friend
    #395677
    Hi sushismb
    I tried to fix it but not sure why the space is appearing on top of the template and it seems that this is how the demo template looks in IE 8 as well.. I have raised a bug report for this and you can check the fixing progress at http://pm.joomlart.com/browse/JATCTELINE-5. I would also suggest you to go for latest Teline template based on JAT3 framework which provides lot of features..
    chavan Friend
    #396230
    Hello Sushismb,
    We had edited css for this issue in IE8. Please follow these steps :
    – open mod_janews_fp.css and add
    .headline.ja-zinhlwrap { width:100%; height:290px; }
    – open ie8.css and add
    #ja-content .ja-zinhl-inner .clearfix { width:auto; display:block }
    #ja-mainnavwrap2 { height:24px; display:block }
    #Top { display:none }
    We will release new version soon, please check later.
    Hope this works for your side, please let me know if have any problem.
    Thanks.
This topic contains 7 replies, has 3 voices, and was last updated by  chavan 13 years, 6 months ago.
