  • soedesh Friend
    #186168
    Hi, just finished my website and came to conclusion that there are MAJOR problems with IE. These problems are also on
    the demo template on your site. Just click on an image in the portfolio section and see what happens with the layout. >:(
    http://joomla25-templates.joomlart.com/ja_onepage/83-content-popup/96-solid-style.html
    Phill Moderator
    #487636
    Works fine in IE9 for me and I have tested on 3 different machines in XP, Vista and Win7. Also tested on IE10 on a Win8 box. Can you give us screenshots of what you are seeing?
    soedesh Friend
    #487637
    Here is an image after closed the popup
    after refresh looks normal
    1. onepage
    2. refresh
    phong nam Friend
    #487663
    Hi soedesh,
    Thanks for your feedback. I have informed the dev team for fixing the issue.
    Regards,
    Leo
    soedesh Friend
    #487734
    Thanks for quick reply, please inform when update is ready.
This topic contains 5 replies, has 3 voices, and was last updated by  soedesh 11 years, 9 months ago.
