  • pierotemplate1 Friend
    #154423
    Sorry for my English, i have serious problems with ja voice, the component is not working well, is very slow, even in the simple switch from the tab of “voices” in the front end, where the voices are not displayed correctly (root menu) and and keys to insert a new item (it is the key of the first type of voice) I also have problems with the forums are not displayed when inserting new “voices” and do not allow the publication by the front end.
    I have re-installed the latest version and updated. The template of my wesite is edenite.
    the images of front-end.
    Anonymous Moderator
    #356025
    Really sorry to hear of these unexpected issues.
    Please give me your ftp and admin account for closer check. You can send it via ticketID: RAA-901676, (log into http://support.joomlart.com then view your tickets). Your information will be saved and secured. Thanks.
This topic contains 2 replies, has 2 voices, and was last updated by Anonymous 14 years, 3 months ago.
