  • fmolina Friend
    #203443
    Hello.
    I have a problem on my site with homepage ja_sidenews
    It is very curious.
    Is disabled and yet it works.
    I can not change the homepage sidenews
    or not find the system.
    Moreover the articles are opened on the same page but have a menu category.
    Can you help me.
    Thanks.
    Pankaj Sharma Moderator
    #558093
    Hi i am not able to open your site admin panel . Please check the admin details that you submitted for JA Staff .
    + add a screenshot of the module that you are talking on homepage .
    I will check it on your site .
    fmolina Friend
    #558128
    Thanks.
    How I send by private the admin details?
    I add a screenshot.
    You can see the problem zone (
    You can see the problem when open the articles in homepage
    You can see the list of articles
    And you can see that not is active a module but is running:confused:
    Thanks.
    1. ja_1
    2. ja_2
    3. ja_3
    4. ja_4
    #558138
    Hi send me admin details Via Private Message . Click on my Profile name . you can see this option.
    fmolina Friend
    #558171
    Is Solve. Thanks
This topic contains 5 replies, has 2 voices, and was last updated by  fmolina 10 years ago.
