  • tom_laan84 Friend
    #187874
    Either i must be really dumb or i dont know what. but somehow i can’t seem to figure out where do i change the width of the ja-right position when ja-right-mass-top is displayed.
    Normal is 21.5%, when the wider ja-right-mass-top is displayed it changes to 43%. I can’t seem to figure out where to change it.
    Been searching forum and google for over an hour.
    HELP! haha.
    Tom
    TomC Moderator
    #494421
    How are you trying to modify the width parameter?
    Please provide the url of the site you’re working on – as well as set “Optimize CSS” to “No” within your Template Manager–General settings.
    tom_laan84 Friend
    #495009
    Hi TomC,
    Thanks for the fast reply. I tried editing it through the template manager layout page. with “Colwidth” or “Specialwidth”, nothing happened. I have optimize CSS off and developer mode turned on. T3 cache cleared.
    http://www.mondiaalbeleid.nl/hometest.html
    Tom
    PS:
    BTW: I fixed it by just putting both in Ja-right and duplicate default layout. change 21.5 to 33.
    I didn;t need the two column underneath it anyway. But still i would like to know how to adjust it for future reference.
    TomC Moderator
    #495053
    Just so we’re on the same page as to which elements on your site you’re referring to . . .
    which elements on your site are you referring to (as it is displaying now)?
This topic contains 4 replies, has 2 voices, and was last updated by  TomC 11 years, 7 months ago.
