max_santiago
Friend
max_santiago
- January 2013
- 8 times in 3 posts
August 22, 2017 at 4:11 pm #1057965Hi, I want set a top-padding of a clients-module in homepage (site in production at moment). You can see there is too much ‘blank space’ on top of the module. Can you help me? Thanks!
M.
This topic was modified 7 years, 5 months ago by
max_santiago.
August 23, 2017 at 1:38 am #1058026Hi
Can you share working site URL here, I will check and suggest you changes based on your site.Regards
max_santiago
Friend
max_santiago
- January 2013
August 24, 2017 at 10:33 am #1058399This reply has been marked as private.
August 25, 2017 at 3:45 am #1058512Hi
Add this code in the custom.css file to change the padding value as per needs.@media (min-width: 1200px) { .t3-section.pt-x2 .container { padding-top: 168px; }}Regards
max_santiago
Friend
max_santiago
- January 2013
August 28, 2017 at 1:36 pm #1058949Hi
Add this code in the custom.css file to change the padding value as per needs.<pre class="prettyprint linenums:1 prettyprinted" style="">
- <span class="lit">@media <span class="pln"> <span class="pun">(<span class="pln">min<span class="pun">-<span class="pln">width<span class="pun">: <span class="pln"> <span class="lit">1200px<span class="pun">)
- <span class="pun">{
- <span class="pun">.<span class="pln">t3<span class="pun">-<span class="pln">section<span class="pun">.<span class="pln">pt<span class="pun">-<span class="pln">x2 <span class="pun">.<span class="pln">container <span class="pun">{
- <span class="pln">padding<span class="pun">-<span class="pln">top<span class="pun">: <span class="pln"> <span class="lit">168px<span class="pun">;
- <span class="pun">}}
Good, thanks Pankaj!
max_santiago 7 years, 5 months ago.We moved to new unified forum. Please post all new support queries in our New Forum
Setting Clients Module top-padding in homepage
