  • neurdenburg Friend
    #187210
    Hi folks,
    When you set the slideshow option to ‘fade’ in stead of ‘custom’ the roll-over behaviour of the CMS buttons in the “Our Services’ module no longer functions correctly. The roll-over effect does work if you move the cursor over the text below the icons (about a 100 pixels lower).
    Any tips on how to fix this?
    thanks,
    Mark
    Hi Mark,
    Which version of Joomla are you using? I use this template with Joomla 2.5, change slideshow type to Fade but roll-over behaviour of these CMS buttons still work as normal.
    You can post your site url here for further checking.
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 11 years, 7 months ago.
