James Weston Friend
James Weston
- 16 times in 1 posts
March 12, 2015 at 4:48 pm #204602Hi Guys,
Can someone help me out with the settings for clients 1 and Clients 2.
I want to have a logo of the presenting sponsor centered on a line on its own and then under it other logos on several lines for the other sponsors.
When I use the JoomlArt Advanced Custom Module it only gives me the style choice of style1. If I use that style it means the logo is not centred unless I put a blank logo in position 1 and position 3. This is exactly how I would like it when you scroll down here http://www.jakartacocktailweek.com/index.php BUT I obviously don’t want the blank logos above and below it.
Is there some code I can add to this module to make the logo centered when there is only one logo on the line in the module?
Many thanks Jim
Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
March 15, 2015 at 8:45 am #563107Hi @origomedia,
Could you please provide your site url and a mockup screenshot about what you want to achieve so I can assist you better ?
James Weston FriendJames Weston
March 15, 2015 at 9:17 am #563110Hi Adam,
the URL is in the above post http://www.jakartacocktailweek.com
What I want to do is be able to have one logo on one line and have it centered (Presenting Sponsor) and then create client 2 which could have more logos as they are the regular sponsors.
When I try to put just one logo in client one I cannot get it to center. Or if i put it at position 2 with no logo at position one it still shows a marker where that image should be; as per the attached screenshot.
Many thanks Jim
- May 2014
March 16, 2015 at 6:50 am #563208Hi @origomedia,
Please open file root_folder/templates/uber/css/custom.css (if you don’t have this file, just create a new one) then add this code :
.uber-cliens .client-img {
text-align: center;
.uber-cliens .client-img .img-responsive {
display: inline-block;
}then you can remove redundant blank logo in your module.
March 16, 2015 at 9:44 am #563240Thanks Adam,
That is great. How do I close up the gaps? Trying to find it in firefox but struggling.
UPDATE. Hi @adam M I managed to do some of the things I wanted, like closing the margin and the font size but there is one gap I cannot figure out
Jim
Adam M Moderator
Adam M
- May 2014
March 17, 2015 at 4:18 am #563346Hi Jim,
Please open this module, switch to Advanced tab and in Module Class Suffix, insert a custom class like “ no-hmargin” (there’s a white space before the class name and without double quote).
Next, open custom.css file as mentioned in previous reply then add this code :
.sections-wrap .section.no-hmargin .section-title {
margin-bottom: 0;
}1 user says Thank You to Adam M for this useful post
March 17, 2015 at 7:39 am #563370Thanks Adam M you guys are brilliant.
All the best Jim
Viewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 2 voices, and was last updated by James Weston 9 years, 8 months ago.
