kuschel Friend
kuschel
- February 2011
- 3 times in 1 posts
October 25, 2012 at 12:18 pm #181697Hallo,
Thank you very much for this very nice template. This is the best of all.
Everythink works fine – except:
I want to show some images without link readmore, Title, intro-text, categorie. So i put the pictures in k2-items with a k2-categorie “Text”. The settings are all on “dont show” for these things. BUt i still see the Categorie, Date, Title and Read-More. The Entry-Text is gone.
Where do i have to do the settings, so i can see only the picture?
You can see it here:http://www.kuschel-wellness.de/index.php/winter
The first entry “Skigenuss und Rodelspass” i want to see without title…Thank you very much for your help.
Brigitte
arucardx Friendarucardx
- July 2010
- 138 times in 104 posts
October 26, 2012 at 2:26 am #471129I think it’s inheriting permission from another category.
kuschel Friendkuschel
- February 2011
October 26, 2012 at 6:55 am #471148Hello,
i have only one more category-settings in category “Kuschel”. Also there is set, that the categoryname and created-date should not be shown. but it shows.
So i tested some settings, but none of them work. So please tell me, where can i change setting for the wall.
You can test if you want.
Two categories: “Text” and “Kuschel”
- February 2011
October 26, 2012 at 7:16 am #471153I tested:
if the menu-setting is a k2-category evertything works fine, but i have a k2-tag page. And there it does not work. And the parameters are not taken from 1 category, because sometimes the into-text is shown and sometimes it does not show.
So what can i do. I need a “tag” paging.
Thank your very much for your help. I hope you understand my bad english.
Brigitte
Stork11 FriendStork11
- March 2011
- 431 times in 393 posts
October 27, 2012 at 9:46 am #471255Hello kuschel,
I have checked and could see that your question relates to specific customization and requires to re-change your whole markup structure. Really sorry that such request exceeds the scope of our service.
You can find a good developer/webmaster who is good at Joomla to help you get the desired effect (you can look for good developer/webmaster via Joomlancers.com, a reliable freelance site: Joomlancers.com, another network of JoomlArt as I personally recommend as thousands of projects have succeeded on this site).
Regards.
- February 2011
October 30, 2012 at 7:28 pm #471481Thank you for your Answer.
But i don’t understand. The k2-Tag-Page is a standard-menu-option.
I only want, that the category-settings work proberly.
At the k2-category-page it works fine. This is how i need it. you can see here http://www.kuschel-wellness.de/index.php/template-2
so what is the difference. Why do i need a developer?Thank you very much
Brigitte
- March 2011
November 1, 2012 at 10:02 am #471673Hello kuschel,
All items In a “wall” are the same style. If you would like to apply custom style on some items, you must do some custom work. We can’t support customization as it is beyond the support scope.
Thank you for your understanding.
Regards.
- July 2010
November 2, 2012 at 3:02 am #471715I checked both showcase and tag page and I don’t understand what the problem in question is. Both page are completely different.
But then tag options are slightly complicated in K2. I think the options you are looking for is in the K2 parameters. It’s a button on the top right of your screen when you are in the K2 component. There should be some display options for Tag listing page. There is where you control the introtext to display or hide.
- February 2011
November 6, 2012 at 2:46 pm #472067Hello arucardx,
thank you vor your answer. i made too screenshots with the views to explain to you.
I also found the k2 settings. This settings are only for backend, it seems like this. I give you also a screenshot.
Thank you much for your help. I love your wall and i really would like to use it.
Brigitte
- arucardx Friend
arucardx
- July 2010
November 7, 2012 at 7:22 am #472132Ok since there’s a language barrier, let me try to use numbers instead.
The tag settings need to be done at “Layout & view options for tag listings” which is under “Layout & Views”.
That is the first tab of the K2 parameters. Then from there, you scroll down to the 3rd section to find the settings for tags.
Alternatively, depending on your setting. You can look for tag.php in the ja_wall or default folder then remove the unwanted code directly from there.
- February 2011
November 7, 2012 at 9:56 am #472148Hallo arucarx,
thank you for your answer. Yes i found the settings in the component. There i changed the setting “show category”, Date created. But this settings are for all categories.
I think, i need the settings for a category.
Is this possible?
If not, is there a chance to put a css-class in the extra-field like “grid-double dark”, which is not showing the intro-text, title, and readmore.
Thank you very, very much for your help.
Brigitte
- July 2010
November 7, 2012 at 10:08 am #472149Just go to template.css and look for the style dark. Should be item.dark then set display: none; for everything that you want to hide.
So when the style dark is applied, those text fields will be hidden and it will only affect style dark. It’s impossible to pull the category settings for tag page due to the way K2 works.
1 user says Thank You to arucardx for this useful post
- February 2011
November 7, 2012 at 4:44 pm #472189hello arucardx,
this ist great. it works fine.
I used the extra-field = sticky and changed template.css
.item.sticky .header, .item.sticky .content, .item.sticky .readmore, .item.sticky .footer {
display: none;
}Everthing is great. THank you very much for your help. I am the happiest woman in the world.
AuthorPostsViewing 13 posts - 1 through 13 (of 13 total)This topic contains 13 replies, has 3 voices, and was last updated by kuschel 12 years, 2 months ago.
