  • grahamm93 Friend
    #163326
    I just installed JA How and I have several problems:
    First I have this error on the admin page but also on the site:
    Deprecated: Function ereg () is deprecated in / homez.342/kappatau/www/components/com_jacomment/helpers/jahelper.php on line 351
    – Then at the site, I have a bug on the top and bottom of the site.
    – Comments register fine, but when submitting the comment, it gets stuck on “Loading “.
    – Avatars of JomSocial not displayed.
    – It is not possible to activate the activity stream in JomSocial.
    Thank you in advance for your help.
    You can see what it gives to this address: http://kappatau.fr/kappa-tau/histoires-de-kt/27-on-attaque-le-menage-de-printemps
    bigbib Friend
    #394041
    Bonjour grahamm, j’ai la meme erreur que toi avec “Deprecated: Function ereg() is deprecated in /homez.373/standard/www/components/com_jacomment/helpers/jahelper.php on line 351” et j’ai vu que sur ton site, les commentaires fonctionne, peux-tu me dire comment tu as fait?
    Je t’en remercie d’avance
    le lien du mien est http://www.standarddeliege-video.be
    Good morning grahamm, I have the meme error that you with “Deprecated: Function ereg() is deprecated in /homez.373/standard/www/components/com_jacomment/helpers/jahelper.php on line 351” and I saw that on your site, comments works, can you say to me how you made?
    I thank you for it beforehand
    the link of mine is http://www.standarddeliege-video.be
    bronze_en Friend
    #396692
    I have the same error massage
    “Deprecated: Function ereg() is deprecated in /Applications/XAMPP/xamppfiles/htdocs/bzv2/components/com_jacomment/helpers/jahelper.php on line 351”
    How can i fix it?
    Stork11 Friend
    #396811
    Hello all,
    I have a solution for your problems.
    For the first one, you can open file “/components/com_jacomment/helpers/jahelper.php”, on line 351
    and replace
    [PHP]if(ereg(‘MSIE 7.0’,$_SERVER[‘HTTP_USER_AGENT’])){ [/PHP]
    by
    [PHP]if (preg_match(‘/MSIE 7.0/’, $_SERVER[‘HTTP_USER_AGENT’])) {[/PHP]
    For the second one with JomSocial, please open file “/components/com_jacomment/helpers/jahelper.php”, on line 1747
    and replace
    [PHP]$query = ” SELECT Count(*) FROM #__components as c WHERE c.option =’$component’ “;[/PHP]
    by
    [PHP]$query = ” SELECT Count(*) FROM #__extensions as c WHERE c.element =’$component’ “;[/PHP]
    Best regards.
    kostrom Friend
    #398131
    I’m having the same “loading” problem. I’m on the JA Business template.
    I submitted a ticket a while back but haven’t received an answer.
    http://www.joomlart.com/forums/topic/javascript-error-after-post-a-comment/
    Any ideas?
    Stork11 Friend
    #398633
    <em>@kostrom 249274 wrote:</em><blockquote>I’m having the same “loading” problem. I’m on the JA Business template.
    Any ideas?</blockquote>
    Please use this link http://support.joomlart.com/index.php?/Tickets/Ticket/View/75327 to update your site information and your FTP account. So I can diagnose it.
    Thank you.
    kostrom Friend
    #399399
    No word from you yet and my ticket was marked closed.
    Stork11 Friend
    #399479
    <em>@kostrom 250858 wrote:</em><blockquote>No word from you yet and my ticket was marked closed.</blockquote>
    You posted a lot of duplicated tickets and you said that I can disregard them. So I closed all duplicated tickets and you can now follow this link http://support.joomlart.com/index.php?/Tickets/Ticket/View/75327 for progress of the problem.
    BTW, I debugged on your site and didn’t find the reason why JA Comment can’t be display with your K2 content. I will continue working on your issue and will inform you when I finish ASAP.
    Thank you for your patience.
    kostrom Friend
    #399649
    Great! Thank you! I’ll wait to hear from you.
    kostrom Friend
    #400591
    Site is going live tomorrow and I still have not heard from you. I am going to have to go live with K2 comments instead. I still need a resolve for this but the site is now live so I don’t know the best way to proceed. Please don’t put in any debugging or turn anything on until it is working.
This topic contains 10 replies, has 5 voices, and was last updated by  kostrom 13 years, 4 months ago.
