  • salvomic Friend
    #144830
    hi all,
    I have severe problem with menu (I use magazin menu) and the CSS in Internet Explorer 7 and 8: I see them as a list, not with the CSS applied…
    Please, help.
    TIA
    salvo
    salvomic Friend
    #319453
    I found that, instead of this code
    <!– MAIN NAVIGATION –>
    <div id=”ja-mainnav” class=”wrap”>
    <div class=”main clearfix”>
    <ul id=”ja-cssmenu” class=”clearfix”>
    <li class=”active”>
    In IE I can see this one
    <li >
    then “<li>” without «class=”active”»
    Why?
    thatch10 Friend
    #319454
    salvomic
    I am currently having a problem with the home menu appearing in a list with no formating in ie8.
    I have identified the problem only happend with the JA Bulletin module published. The minute i disable the JA Bulletin Module the menu appears ok.
    Could this be your problem ?
    Thatch
    salvomic Friend
    #319455
    <em>@thatch10 147409 wrote:</em><blockquote>salvomic
    </blockquote>
    Not here: I’ve tried just now to disable JA_bulletin and the issue it still there: a list without formatting…
    I must tell I’ve now Bulletin in a JA_tabs module.
    It could be also another module.
    cheers
    salvo
    salvomic Friend
    #319456
    @ thach10
    here, instead, is ja_widget_stock: when active the html page give a “tool tip not defined” and the menu are presented as list, when not active all it’s ok.
    However, a friend of mine told me that with IE 7 there are the same issue and the menus are presented always as list…
    Update: after having do some tests, now *also* disabling* ja_widget_stock I’ve the same issue: menu as list…
    salvomic Friend
    #319479
    @thach10
    do you have mod_phocagallery_random_image installed?
    I disabled this module and now all seems to work well here in IE 7/8
    The module, however, works quite well in Safari and Firefox. I would know what’s the error, to use it again.
This topic contains 6 replies, has 2 voices, and was last updated by  salvomic 15 years, 1 month ago.
