  • crazydiver Friend
    #200278
    First, I’d like to thank JA for making a straightforward video tutorial.
    However, I get some problems that I think is because I’m using the language component with the SEF component sh404sef.
    It seems that after making a bing account with azure (and setting up all the API details), I get almost all FAILs after clicking on translate.
    Furthermore, when I publish the module language switcher, there are no flags or option to choose language appears…
    If anyone out there who has experienced similar problems and got it fixed, please advise!
    Thank you!!!
    Hi @crazydiver,
    Please take a look at this thread if you’re in the same situation: http://www.joomlart.com/forums/topic/ja-multilingual-joomla-3-component-problem/
    If the problem still persist, you can PM me URL and admin login info of your site, I will try to check it further.
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 10 years, 3 months ago.
