Viewing 15 posts - 1 through 15 (of 20 total)
  • nilgunce Friend
    #836472
    Something go wrong with my shopping cart module;
    how can I fix the problem?
    https://www.dropbox.com/s/cb2kk6qea4zt51o/Screenshot%202016-01-01%2012.40.28.png?dl=0
    It’s VM – Shopping Cart module in ‘mycart’ position, kindly check the back-end settings of this module and make sure you add the module class suffix for it: http://prntscr.com/9luktd
    nilgunce Friend
    #838219
    Pls check again the screenshot in my above post, you should add a space before the module class suffix name
    nilgunce Friend
    #838950
    This is weird! you can send me the FTP account of your site, I will take a closer look at code of this module.
    nilgunce Friend
    #840421
    I just checked and saw that the folder ‘html’ in /templates/ja_hawkstore/ path doesn’t exist and that’s why the format is wrong. I tried to upload the default file of this template but seems that I don’t have permission.
    could you upload it again?
    nilgunce Friend
    #840844
    It works.
    great
    thanks.
    You’re welcome!!!
    nilgunce Friend
    #840886
    Hi again;
    A new problem occured.
    Whan click on add to cart button the front end appereance goes wrong as you see on above linked screenshot.
    https://www.dropbox.com/s/obg2lj5gzm3bzpr/Screenshot%202016-01-07%2013.18.21.png?dl=0
    Could you pls check the package of this template and update the files for that ‘html’ folder?
    why did you remove that folder?
    nilgunce Friend
    #841370
    A few days ago some probles occurd om my hosting provider(arvixe) and I upload the site from backup and the problems is occured while uploading the local backup files. I did not made it intentionally.
    You know I upload the missing files from template and my initial problem is solved(shopping cart works fine)
    But for now; whan I add a product to the cart, hoıma page appereance goes wrong. (as you can see on screenshot)
    I am waiting your kind assistance.
    Could you update the admin account again? I can’t access your site again with credentials you sent.
    nilgunce Friend
    #843008
This topic contains 19 replies, has 2 voices, and was last updated by  Saguaros 8 years, 11 months ago.
