March 22, 2013 at 4:39 pm #186102
My website is currently showing frontpage items in the frontpage itsself, as I guess the masonry thing is supposed to do.
I would like, though, that each item opens in its own page (and not in the frontpage , shifting the other articles to the side).
Do you know how I can achieve this?
Thank you!
AminMarch 25, 2013 at 3:25 pm #487762Hi once again,
I have seen some sites that seem to work with this “open item in new page and not in frontpage” thing.
I was hoping it could be something quite simple.Anyone have any ideas?
Thanks!
swissa Friendswissa
- November 2011
- 717 times in 572 posts
March 25, 2013 at 3:36 pm #487765<em>@amam 366135 wrote:</em><blockquote>Hi once again,
Thanks!</blockquote>
It is really simple! Go to admin / template manager / ja_lens / and in Advanced Options on the right set ‘Popup preview’ to ‘no’.
March 25, 2013 at 3:43 pm #487766Hi Swissa,
Thanks for the fast reply. In fact i tried this but it did not work. Do you have information if this particular functionality had any bug in the past (that eventually got fixed in new releases)? Is there any manual modification that i could do to make it work?
I havent done any updates for a while since they will require some manual maintenance..
swissa Friendswissa
- November 2011
March 25, 2013 at 3:50 pm #487768I don’t recall seeing any bugs flagged up regarding this in earlier versions.
Could be a browser cache issue – have you tried clearing the cache or using a new browser?
Otherwise, I’d do an akeeba backup, save it to your desktop, copy any edited css files to your desktop too and then use JA Extension Manager to do an update. See if it fixes the issue and then copy back your css edits.
Luna Garden ModeratorLuna Garden
- July 2011
- 453 times in 425 posts
March 26, 2013 at 2:50 am #487849Hello Amin,
In order to make each item opens in its own page, go to backend >> template manager >> JA Lens >> Set like this capture: http://easycaptures.com/fs/uploaded/584/7822383717.png
Hope this helps.
March 26, 2013 at 10:55 am #487890Hi Swissa and Luna,
It is exactly this that was not working with my (previous) version of the template. However, updating it to the most recent version solves the problem (i couldnt tell exactly which file was involved but its something inside the templates/ja-lens folder).
Thanks for the support!
This topic contains 7 replies, has 3 voices, and was last updated by amam 11 years, 6 months ago.
