January 12, 2011 at 1:40 am #158625
How do I place two side-by-side positions under the slideshow? :confused:
I’ve attached a picture showing what I mean.
Thanks.
Sherlock FriendSherlock
- 2478 times in 2162 posts
January 14, 2011 at 2:02 am #371784Dear radeonmaster,
You can go to your template back-end >> LAYOUTS tabs >> Going to edit Your actived layout,You can add a new block xml tag like below under the blocks tag that name “middle”
<block name=”content-top” type=”spotlight”>newposition1,newposition2</block>I hope this would help !
1 user says Thank You to Sherlock for this useful post
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by Sherlock 13 years, 11 months ago.
