August 1, 2012 at 12:23 am #179554
I am trying to display two modules side-by-side within the same module position rather than one on top of the other. Specifically, the Search Module and a Menu Module in the Video position of JA Methys. I’ve seen a variety of responses for other templates, but nothing that has really helped to achieve this.
Has anyone had success at this?
Thank you!
Saguaros ModeratorSaguaros
August 1, 2012 at 7:32 am #462809Hi brandywine,
Could you post your site url here and set Compress Css in Template manager to No and if possible a screenshot of how you wanna achieve?
August 2, 2012 at 2:38 am #462906Hi Saguaros,
Thank you for your willingness to help with my question! I sent you a PM with the URL and front-end login details. I also set “compress css” to no and have attached a screenshot of what I’m trying to accomplish. In the screenshot, I have the search module enabled in the “video” module position………then the menu items to the right in the same module position (Activities, Resources, Contact) are what I’m trying to achieve.
Thank you!
Brandywine
August 2, 2012 at 4:11 am #462927Could you pm a temporary admin account? I cannot access with account you gave.
Regards.
August 2, 2012 at 5:10 am #462933Just PM’d you. Thanks!
August 2, 2012 at 10:06 am #462962Hi brandywine,
Do you mean like this? http://easycaptures.com/fs/uploaded/615/5774027536.png
If so, please open your template.css file and add this code:
#ja-mainnav {
left: 640px;
top: 106px;
}Hope this’s what you wanna achieve.
August 3, 2012 at 8:02 am #463045Very similar except that I need the mainnav to remain where it is in the header, and a second menu aligned side by side with the search bar in the video position. Is it possible to accomplish this with similar CSS? Thank you for your help!
August 3, 2012 at 10:02 am #463057It maybe the same and depends on position you wanna locate it and change to your desired value
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 2 voices, and was last updated by Saguaros 12 years, 4 months ago.
Side by Side Modules in One Module Position
