Viewing 15 posts - 1 through 15 (of 26 total)
  • funci Friend
    #206045
    I am trying to get some modules in positions “sidebar-1” and “sidebar-2” but without success!
    Can somebody help me?
    Domain is on: http://www.rent-a-gs.com
    <em>@funci 471611 wrote:</em><blockquote>Hi,
    Domain is on: http://www.rent-a-gs.com</blockquote>
    Could you send me via Private Message a super user account to your backend ? i will have a look at your configuration.
    Did you checked also documentation about Ja Jason Module positions HERE ?
    funci Friend
    #569263
    Hi Pavit,
    I am sending you PM
    <em>@funci 471670 wrote:</em><blockquote>Hi Pavit,
    I am sending you PM</blockquote>
    Your pages have assigned all the Home layouts ( Home-1, Home-2, Home-3 etc. ) while sidebar positions are available inside Default layout so you have to switch menu items where you want sidebar positions availables from Home layout to default.
    funci Friend
    #569280
    So there is no possibility to have sidebar on homepage (in present configuration)?
    <em>@funci 471691 wrote:</em><blockquote>So there is no possibility to have sidebar on homepage (in present configuration)?</blockquote>
    Not with the Home layout , you should change to Default layout
    funci Friend
    #569333
    Hi Pavit,
    I’ve changed on page “O nama” to default, but now I get dark layer on top, over menu. Can you tell me how to remove it?
    1. sivi-leyer
    I applied a css class .nomask to the header for the specific page to set the header to no background , as you can see it works correctly now
    funci Friend
    #569342
    Thx for that!
    Now I’ve notiecd that I can’t click on flags to change language. Why is that?
    <em>@funci 471767 wrote:</em><blockquote>Thx for that!
    Now I’ve notiecd that I can’t click on flags to change language. Why is that?</blockquote>
    Please check now
    I added a lower height to the header for the specific page.
    Please check now
    funci Friend
    #569415
    Thx Pavit!
    But now owner want to go back on previous look… Sorry :((
    funci Friend
    #734504
    Thx Pavit!
    <em>@funci 471861 wrote:</em><blockquote>Thx Pavit!
    But now owner want to go back on previous look… Sorry :((</blockquote>
    what is the problem then ? could you explain in details ?
This topic contains 26 replies, has 2 voices, and was last updated by  funci 9 years, 7 months ago.
