  • tabbus Friend
    #981834
    Hello, There’s a problem with a site I’m working on it was fine today, I changed an item in my custom css, it appeared fine the change occurred, on returning to the site after a hour or so, the entire layout had gone, and it looks like the javascript isn’t functioning properly.
    Can anyone assist?
    tabbus Friend
    #981869
    It appears all the layout settings have disappeared
    Pankaj Sharma Moderator
    #981876
    In this case i need to check the issue on your site , kindly provide me the description of the issue with a screenshot and send me site admin details via private reply .
    I will check it .
    tabbus Friend
    #982021
    #982077
    could u give me the description of the issue with a screenshot ?
    I am not able to get the exact issue on your site
    tabbus Friend
    #982092
    #982129
    Homepage using the feature intro template style-2 that does not have the slideshow position .
    I changed it to feature intro : http://prntscr.com/d1aiyy
    Now you can see the slideshow .
    For the css issue , this is issue from your server, the t3-assets folder is giving 403 error : http://prntscr.com/d1ajsr
    kindly contact to your hosting support to fix it .
    tabbus Friend
    #982149
    Thanks for getting back, but why after all the months the layout has been correct has it gone over night?
    #982219
    as u can see the issue is due to the css are not loading , once the forbidden issue solved , i think the site will work fine .
    Let me know if still issue is present on site .
    tabbus Friend
    #982326
    Its to do with a server error then, but all the layout settings I had have been changed, I’ll need to go back and do them again.
    tabbus Friend
    #982330
    It’s returned back to the same issue.
    I had all this set up the site was working fine with everything as it should be, now I have to start from scratch again.
    All the settings are completely wrong.
    The slideshow is not appearing on the home page the home isn’t the correct layout either.
    The home page layout should be as it is in the screen shot, only with the slideshow, why if it’s a server error does the correct header appear under the following:
    http://upgrade.saltminetrust.org.uk/index.php/theatre-company/ethos
    1. Screenshot-2016-10-31-14.19.35
    tabbus Friend
    #982340
    #982565
    The homepage loading fine : http://prntscr.com/d1xxbc
    Also the video page : http://prntscr.com/d1xxhe
    There is no issue in style now .
This topic contains 12 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 2 months ago.
