  • bob_sprague Friend
    #174867
    I manage a 1.5.25 site (http://www.yourarlington.com), but aim to migrate to 2.5 this year. I am looking for a new template that loads faster, and JA Purity II looks like a possibility, though I would need to adjust the right column to allow a 250px ad.
    Does the T3 Framework incorporate the best practices for site speed described below?
    http://developer.yahoo.com/performan….html#num_http
    Thanks for any advice from developers.
    Bob Sprague
    Bob Sprague
    Manos Moderator
    #443108
    I am pretty sure that JA T3 can do better than that!
    Grade Overall performance score 58
    But you have to understand that a better server is always a better solution! 😀
    bob_sprague Friend
    #443161
    <em>@pascm 306802 wrote:</em><blockquote>Hello,
    </blockquote>
    I should hope so, and I agree with you about the server. But can you respond specifically to the question I asked? Does JA T3 incorporate the best practices cited?
    Bob
    Bob Sprague
    Manos Moderator
    #443679
    Yes JA T3 incorporate the best practices and also keeps the compatibility with Joomla and almost every component/module/plugin that’s out there (JED)
    bob_sprague Friend
    #443690
    <em>@pascm 307532 wrote:</em><blockquote>Hi,
    Yes JA T3 incorporate the best practices and also keeps the compatibility with Joomla and almost every component/module/plugin that’s out there (JED)</blockquote>
    Thanks much, pascm. I appreciate your answer.
    Bob
    Bob Sprague
This topic contains 5 replies, has 2 voices, and was last updated by  bob_sprague 12 years, 8 months ago.
