  • avabanet Friend
    #167279
    I can not see the part of sl1-r, the modules are activated but i don´t know what the problem.
    other problem is that t3-assets folder don`t work, optimization css is disabled for working
    thank you very much
    Manos Moderator
    #405629
    Hi, is this ok for you now ?
    avabanet Friend
    #405778
    <em>@pascm 258956 wrote:</em><blockquote>Hi, is this ok for you now ?</blockquote>
    OK, is perfect, thanks
    avabanet Friend
    #405785
    No, no sorryyyy, now when enter in for example, custon html module don´t have editor, i try change the editor, but don´t work, is posible that you touch the configuration?
    Please can you saw the problem………….
    Manos Moderator
    #405811
    Hi, no i didn’t touch any configuration but i will take a look at your problem, just give me a few minutes.
    Manos Moderator
    #405812
    Please try again and tell me if everything is ok now!
This topic contains 6 replies, has 2 voices, and was last updated by  Manos 13 years, 3 months ago.
