  • friseurberater Friend
    #1025995
    i added slider to position top. standard is 3 sliders. added a 4. one and the tryed to adjust this added one by double click. doesn’t work. the options don’t appear on the screen as it is with the 3 slider which are standard.
    Please help.
    THX
    gringo211985 Friend
    #1026033
    I can confirm also that the slideshow is not working correctly, when I add any new slide items the images are not showing regardless of any settings
    I’ve passed to the team for further checking, pls stay tuned.
    This is know issue on Chrome that when an element on the page has a background image that uses:
    background-attachment: fixed;
    Hence in Edit mode of page where you show slideshow, check the 2nd slide or the new slide you added > OVERLAY tab > BACKGROUND ATTACHMENT option and make sure that you don’t select ‘fixed’ option: http://prntscr.com/evtjlr
    Then publish the page + clear browser’s cache, it will work then.
    gringo211985 Friend
    #1026247
    Hi Saguaros,
    Thanks, that has worked.
    So to solve it make sure you only use fixed background attachment on first item.
    Thanks,
    Richard
    Glad to hear it works now!
This topic contains 5 replies, has 3 voices, and was last updated by  Saguaros 7 years, 9 months ago.
