April 6, 2011 at 12:45 am #162416
How do I disable the scroll on the slideshow module? I want to use it to descend and ascend the page instead of changing the articles display when the cursor is above the module. In 1.5 this does not occur only in 1.6. Thanks
Sherlock FriendSherlock
- 2478 times in 2162 posts
April 6, 2011 at 10:05 am #385137Hi alexmarinho,
It is not clear from what you are talking about,Kindly explain it a little bit more details,attach a screenshot if possible.
April 6, 2011 at 8:40 pm #385221Sorry for my bad english =)
When the cursor is over the thumbnail of the slideshow (1.6 version), the scroll mouse doesn’t move the screen vertically as usual, but change the slides (horizontally). I’d like to disable this, as is in joomla 1.5 version. You can see it happen just checking both demo versions of JA_Business. At the 1.6 version, the horizontall scroll function is habilited, at the 1.5, isn’t.
Thank’s.
April 8, 2011 at 9:39 am #385398hi alexmarinho,
I checked the demo of JA_Business for joomla 1.6 here http://joomla16-templates.joomlart.com/ja_business/ and it is hard to see the problem there,Kindly attach an image if possible.
April 8, 2011 at 1:33 pm #385428Printscreen attached. Try enter in my site exactsim.com.br, put the cursor over the thumbnail (any place inside the red retangle) and use the mouse scroll. What I need to change to roll the page vertically instead the slides? At ja_business 1.5 the slides don’t change when mouse scroll is used.
Thanks!
April 9, 2011 at 2:58 am #385458Hi alexmarinho,
OK,Now I saw the problem,you can try as below
Open the file modulesmod_jaslideshowassetsscript.js ,Look for this line of code
handlerBox:thumbs_handles,
And change it to
handlerBox:null,Hope that would help !
1 user says Thank You to Sherlock for this useful post
April 9, 2011 at 10:11 am #385522AWESOME MAN!!! It’s works!!!! thank’s a lot!!!
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 2 voices, and was last updated by alexmarinho 13 years, 5 months ago.
Slideshow 1.6 problem with scroll
