  • juanalverto Friend
    #178082
    Hi i am using the Slideshow 3 module in Kranos template, but i need to hide the control buttons from here:
    http://belikeu.com/bk/index.php?option=com_content&view=article&id=69&Itemid=71
    because i only want the image as a header. I tried to do it by selecting NO in the control buttons option in navigation settings, but
    nothing is happening. I hope somebody can help me with this. I should say that i only want to remove the buttons from that slideshow module but still keeping them in my main home site.
    Thanks a lot!
    J.A
    juanalverto Friend
    #457128
    i discovered that my 2 modules are connected some how and when i change the button parameter in one it changes in both, any
    body knows why this could be happening? and how to fix it?
    regards
    #457231
    <em>@juanalverto 325002 wrote:</em><blockquote>i discovered that my 2 modules are connected some how and when i change the button parameter in one it changes in both, any
    regards</blockquote>
    Hi juanalverto,
    In the module back-end you would see a field name Profile if you are choosing to use same Profie for two modules then if you change settings for a module the change is saved to the profile and it also apply for the other module.
    The solution here is that you should use different profile for different module that I think would help.
    juanalverto Friend
    #457328
    Hello!
    That works perfectly, Many thanks!
    All the Best!
This topic contains 4 replies, has 2 voices, and was last updated by  juanalverto 12 years, 7 months ago.
