  • topinwuhan Friend
    #164970
    i have two issues(changes) i am trying to without success,
    1.I want to change the slideshow to show only full image(970px) without tittle,description or anything in slideshow module,which parameter should i change on slideshow module?
    1.I have beed trying to put module suffix, i have been trying to put _blue,_green with no success,is there anything wrong with this?? is yes or no how can i implement this?
    thanks
    topinwuhan Friend
    #395178
    After hard try and error,i got it to work with some problems as shown in pix,so how can i remove it?
    1.Remove the side bars
    3.Remove the gap between two modules
    2.If 1 and 3 are solved,means 3 is not a problem
    Numbers correspinds to the shot
    1. threee
This topic contains 2 replies, has 1 voice, and was last updated by  topinwuhan 13 years, 6 months ago.
