June 30, 2011 at 10:13 pm #165849
Hi, Guys
I am following the JA Minisite Guide to Copy Samples Pictures sl-1.jpg… sl-8.jpg into images/stories/slideshow/, However, when I open the home page, the pictures are missing with only demisiions on it( http://www.dptltd.com). I try to find what exactly path of my images, I found all images are move to images/resize/stories/sildshow, How to fix the problems???? Please Help!Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
June 30, 2011 at 10:28 pm #399415Please could you PM me an admin logon so I can take a look for you?
June 30, 2011 at 10:34 pm #399416<em>@phill luckhurst 250876 wrote:</em><blockquote>Please could you PM me an admin logon so I can take a look for you?</blockquote>
PMed~ Thank you for your reply.
June 30, 2011 at 10:47 pm #399418anything new?
June 30, 2011 at 11:27 pm #399421there are nobody have the same issues?????
June 30, 2011 at 11:37 pm #399422No any response yet? Too bad~:((
July 1, 2011 at 12:44 am #399426Gave up for the bad joomla 1.6 template support!!!go for 1.5 to give a try!>:(
Sherlock FriendSherlock
- 2478 times in 2162 posts
July 2, 2011 at 2:55 am #399573Hi Besmart,
Please go to Module manager, choose JA Slideshow for editting, open Advanced Options tab on right hand, you will see a parameter is Thumbnail Mode, please choose option Using Image source, then module will get images from your config folder.
Regards1 user says Thank You to Sherlock for this useful post
mj1256 Friendmj1256
- June 2007
- 225 times in 118 posts
August 10, 2011 at 7:50 pm #405478I have the issue, no images in the zip file, where do we get the images, the last instruction would be great if the images were actually included with the quickstart iand in the fiolder
- February 2014
August 10, 2011 at 7:56 pm #405481No images are included in the quickstart, only placeholder images. What images are you expecting?. Can you detail exactly what problems you are getting?
mj1256 Friendmj1256
- June 2007
August 12, 2011 at 1:07 pm #405944the slideshow images were not there, but its ok, in another thread someone else provided a link to get them
only problem now is i cannot remove the readmore link, even though i disabled it in the parameters and cleared the cache
I also need to change the font color fo the text, where is that
<em>@phill luckhurst 258791 wrote:</em><blockquote>No images are included in the quickstart, only placeholder images. What images are you expecting?. Can you detail exactly what problems you are getting?</blockquote>
mj1256 Friendmj1256
- June 2007
August 12, 2011 at 1:12 pm #405946found it
As backward as it sounds I enabled the Description & Read more, then set the Show Readmore text to No and it worked. So I guess when a JA extensions says go left I need to go right.
<em>@mj1256 259347 wrote:</em><blockquote>the slideshow images were not there, but its ok, in another thread someone else provided a link to get them
I also need to change the font color fo the text, where is that</blockquote>
mj1256 Friendmj1256
- June 2007
August 12, 2011 at 1:22 pm #405949also i figured out the fond changes
<em>@mj1256 259351 wrote:</em><blockquote>found it
As backward as it sounds I enabled the Description & Read more, then set the Show Readmore text to No and it worked. So I guess when a JA extensions says go left I need to go right.</blockquote>
This topic contains 13 replies, has 4 voices, and was last updated by mj1256 13 years, 1 month ago.
