test melih
 melih
  • somanywindows Friend
    #178777
    Hello
    1) How can I increases the number of words displayed for the slides in the slideshow? Tried changing ss-text in the mod_jaslideshowLite.css file, but no effect.
    2) How can I add more ‘slides’ (image/text/links) to the slideshow? I tried just adding these in the Description field in the slideshowlite module but it did not have any effect.
    Any help is appreciated
    Thanks!
    To add more words you just need to add more text in the description of the slideshow module and increase the height of
    the .ja-ss-desc in the templatesja_mendozitecssmod_jaslideshowlite.css file
    To add more slides simply add new desc with new images and text
    Maybe you need also to clean your JaT3 cache
    zeeshah Friend
    #459894
    I’m also having a problem with the JA slideshow. I can change the images, but there another image/module that overlays all the sliding banners. This is displayed on the homepage of the Mendozite template banner which states “World Wide Experiences.” Where is this module and how can I remove it from the slideshow. Please see my homepage banner http://www.seospecialistsinc.com.
    Also, how do I insert a logo? I see the option of “image” or “text” for logo in the default template section, but not where I can upload the actual logo itself.
    Thanks!
    Rusell Cerrato Friend
    #459900
    Hi, if you are using for example..the blue theme on mendozite.. go here,,,
    templates/ja_mendozite/themes/blue/images
    look for this file.. slide-mask.png and rename like something different than that name.. its a trick that works!
    if you are using the default Theme,, then go here,. /templates/ja_mendozite/images
    look same file!
    good luck!
    #459902
    Thanks Pavit, that worked!
    Your prompt response is appreciated
    Thanks!
    zeeshah Friend
    #459906
    Awesome! that solved the problem!
    One last question 🙂
    How do I easily and quickly create a footer sitemap of all my top menu items?
    Thanks!
    musiqfan Friend
    #460172
    Create a new menu for each item that you would like to display in the various footer positions. Add all of the items and sub items that you would like to display.
    Next, create a new module and specify new menu. Select the menu from the menus you created in the previous steps. Select the appropriate position.
This topic contains 7 replies, has 5 voices, and was last updated by  musiqfan 12 years, 7 months ago.
