  • vpiancastelli Friend
    #198981
    hello,
    I’m using purity 3 template, I’m configuring corporate style.
    The slideshow is slightly different, in fact I can’t see the arrows on both image side
    and the circle in the picture bottom indicating the number of immages.
    Is that normal? I have to setup some parameters?
    Or I need a new module?
    Thanks in advance.
    Eugenio
    Pankaj Sharma Moderator
    #539502
    like this way its hard to assume the issue .
    Please add a screenshot illustrate your problem in it , also share the url of your site , so that we can assist you in a better way 🙂
    #539503
    the url is still PRIVATE. http://repoigg.services.iit.cnr.it/egip/
    As you can see my slideshow don’t have neither the arrows at the edge nor the circles in the bottom of the of the pictures as the slideshow in the corporate template has.
    What is wrong? Do I need an extention? or I set a wrong configuration?
    E.
    #539509
    Its seems you have not added the code of control buttons .
    Please follow this user guide .
    See Step 4 . of Slideshow
    Hope it helps
    #539545
    <em>@pankajsharma 433023 wrote:</em><blockquote>Its seems you have not added the code of control buttons .
    Hope it helps</blockquote>
    I followed that guide, by inserting the indicators and controls that was missing in my html custom code,
    but on saving the changes I see that for indicators, the <ol> has been changed in <ul> and the controls are delated….
    Very strange.
    What can I do?
    E.
    #539583
    Try this
    Go to Global config . >system>default editor > NONE .
    After that add the slideshow code as per documentation in the module editor and save&close .
    Check the frontend .
    #540159
    <em>@pankajsharma 433113 wrote:</em><blockquote>Try this
    Check the frontend .</blockquote>
    Perfect, It works!
    Thank you
This topic contains 7 replies, has 2 voices, and was last updated by  vpiancastelli 10 years, 5 months ago.
