cursosdesign Friend
cursosdesign
- February 2009
- 2 times in 1 posts
November 18, 2009 at 4:26 pm #146152Hi friends!
I´ve a problem with this module slideshow in my site http://www.lestarat.net
1) I can´t see the text in read more.
My code is in slide is:
<h3>Regístrate para ser parte de la comunidad</h3>
<p>Los mejores tragos con Tequila</p>
What is the problem?
2) How can i remove: « Previous ‹Playback Stop Play › Next » ????
3) and the last: How can i change the TV image?
Thanks!!!!
CursosDesign:)
November 18, 2009 at 5:04 pm #324126Hi !
Maybe I can help.
1) Code seems to be ok. Is the “Images Folder” parameter set correctly ? (it’s the first box on module parameters.)
2) In module parameters, set “Control Buttons” to “no”
3) the TV image is a background image that you can change (or delete) at ja.slideshow2.css.
At line 42 (or so) look for .ja-slide-main-wrap .mask and change the background parameterHope this can help
1 user says Thank You to sincta for this useful post
cursosdesign Friendcursosdesign
- February 2009
November 18, 2009 at 5:23 pm #324129Oh! Excelent Sincta!
All problems ok now, but the only one is point one:The images folder is set correctly (images/stories/fruit)
What do you think?Do you want login in my cpanel?
Thanks!
CursosDesign
- February 2009
November 19, 2009 at 2:10 pm #324267Somewhere can Help?:
Saguaros ModeratorSaguaros
November 20, 2009 at 3:46 am #324327Hello cursosdesign!
The problem is from the configuration of ja Slideshow 2,
if you would like display the “reamore” text, you mus to choose “Show Description with Readmore” for the “Show Description” paramter.1 user says Thank You to Saguaros for this useful post
- February 2009
November 20, 2009 at 4:12 am #324332Hello tienhc!
There is not a problem!
the problem is the configuration of the text. Please check the image:Thanks!
CursosDesign
November 20, 2009 at 7:58 am #324354Hello CursosDesign!
Please give me your administrator account via PM or Submit a ticket.
thanks
November 21, 2009 at 4:40 am #324485Hello CursosDesign!
That’s the bug from the JA Template when you set “Image animated” for the Show Description parameter.
Please open the “templatesja_halitehtmlmod_jaslideshow2default.php” file and find a section code at line 21:[PHP] <div class=”ja-slide-desc”><?php // echo $desc?></div> [/PHP]
change:
[PHP] <div class=”ja-slide-desc”><?php echo $desc?></div> [/PHP]the bug have fixed on the JA Halite,
- February 2009
November 23, 2009 at 3:38 am #324646Thanks!!!! And the last: how i change this color text?
Bye, thanks and regards!
CursosDesign
November 23, 2009 at 4:22 am #324648Hello CursosDesign!
Please kindly open the “templates/Halite/css/ja.slideshow2.css” file and try to find a section code:
[PHP]
.maskDesc .ja-slide-desc {
padding: 30px 0 0;
color: #FFFFFF;
font-size: 100%;
width: 600px;
float: left;
}[/PHP]
and
[PHP]
.ja-slide-desc h3 {
color: #fff !important;
margin: 0 0 10px;
padding: 0;
font-weight: bold;
font-size: 300% !important;
text-transform: uppercase;
}.maskDesc .ja-slide-desc p {
line-height: 1.8;
}[/PHP]
You’ll make change of colour in those rules css.
- February 2009
November 23, 2009 at 2:38 pm #324694Thank You VERY Much!!!!!
AuthorPostsViewing 11 posts - 1 through 11 (of 11 total)This topic contains 11 replies, has 3 voices, and was last updated by cursosdesign 15 years, 1 month ago.
Slideshow Problem
