October 10, 2011 at 6:50 pm #169533
Hello all, I’m wondering if you can help me with the following problem:
Once the page has loaded, whenever I resize the browser the main slide of the frontpage slideshow reduces in size accordingly. This gives a really weird result, as you can see in the following screenshot:
Does anyone know how I can make main slide stay the same, regardless of the browser window?
Thanks in advance!
Manos ModeratorManos
- February 2014
- 633 times in 576 posts
October 10, 2011 at 6:53 pm #418296Hi,
If you are trying to resize your browser to a smaller size than the slideshow has then this is normal because there is no other way to resize the slideshow again
October 10, 2011 at 7:37 pm #418316Thanks for the response pacsm, but the problem is that the main slide behaves as if it does not have a fixed width. Can’t the slideshow just ‘center’ in the resized browser – like the rest of the layout ? One would expect the main slide to remain 960px regardless of the window.
- February 2014
October 12, 2011 at 12:31 am #418565Hi,
You could probably try a different layout style as this particular one has no width ( As you can see the slideshow will expand as wide as your screen resolution can support, that’s the effect that has been chosen for this layout )
But JA Slideshow supports by default some more layout profiles you can use!
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by Manos 13 years, 2 months ago.
Slideshow problem
