  • ekaplan1020 Friend
    #169612
    I installed a new module in place of the slideshow. It is hiding the menu drop downs. What do I need to change to get it to work?
    TomC Moderator
    #418952
    <em>@ekaplan1020 275447 wrote:</em><blockquote>I installed a new module in place of the slideshow. It is hiding the menu drop downs. What do I need to change to get it to work?</blockquote>
    Actually, when I looked at your site (in Chrome), the dropdowns appear to work just fine – over the slideshow (as they should).
    By the way, the Frontpage Slideshow component looks great with your developing site design.
    ekaplan1020 Friend
    #418953
    Thanks! I had to change the z-index in the template.css so I think I got it worked out. The only problem I have now is that when I log on, it disappears.
    TomC Moderator
    #418955
    <em>@ekaplan1020 275454 wrote:</em><blockquote>Thanks! I had to change the z-index in the template.css so I think I got it worked out. The only problem I have now is that when I log on, it disappears.</blockquote>
    Good job in figuring out the z-index. Clearly you know what you’re doing … I don’t think many would recognize your site as starting as the base JA Social template.
    What disappears when you log in – the mega menu? The Slideshow component?
    ekaplan1020 Friend
    #418957
    the slideshow seems to disappear.
    TomC Moderator
    #418959
    <em>@ekaplan1020 275458 wrote:</em><blockquote>the slideshow seems to disappear.</blockquote>
    Okay, now THAT’S strange . . .
    I can’t imagine there is a setting for which the slideshow only appears for unregistered users – that wouldn’t make any sense at all. Nevertheless, look through all of the configuration parameters – just in case.
    Otherwise, since it’s a 3rd party component, perhaps there is some kind of javascript conflict – though that wouldn’t make much sense either.
This topic contains 6 replies, has 2 voices, and was last updated by  TomC 13 years ago.
