  • stpere Friend
    #194150
    Hi all
    First, thanks for your fantastic job. Your templates are maybe the best online solution for Joomla 🙂
    And the new purity III seems terrific!
    I’m currently migrating a website (with more than 5 000 articles). So I’m don’t take the quickstart, I try to configure the template/module/plugin for my own content.
    I have some issues with the template, maybe really easy to resolve (I’m not a noob with joomla, but I’ve something to learn with the 3.0 version), I haven’t find the reponse on this forum.
    1/ Article view
    When I click on an article link. I see nothing. (just menu and footer). (See screenshot) I think it’s a problem with template assignation. I have 2 templates. One for the homepage (defaut) and one for all other content.
    When I make the second one by defaut. Thats my homepage who doesn’t work.
    I think it’s easy to resolve, but this bug was see after the installation of a social plugin (JoomShareBar Pro).
    2/ Slideshow and articles list (WHAT’S TRENDING NOW)
    The slideshow (homepage) has always the same image. Do I forget something in the config? (I’ve follow your recommendation in the documentation).
    For articles list, I want to see my images (crop), like in your demo. But I see the complete image on my homepage. Where can I modify it?
    Thanks for your help!
    Pierre
    1. Capture-ha
    stpere Friend
    #520375
    Nobody could help me?
    I really need to see my articles and resolve the slideshow bug :((
    Pierre
    Nazario A Friend
    #521066
    Hi Pierre,
    I’m so sorry for my late reply. I have received your question, but I need time to detect the root of issue. I will get back to you as soon as possible. Appreciate your patience on this.
    stpere Friend
    #521323
    <em>@Nazario A 409289 wrote:</em><blockquote>Hi Pierre,
    I’m so sorry for my late reply. I have received your question, but I need time to detect the root of issue. I will get back to you as soon as possible. Appreciate your patience on this.</blockquote>
    Hi Nazario
    Thanks for your reply
    I’m currently work on this URL: http://www.passionhockey.com/site_final/
    You can log in with the same ID send previously.
    As you can see, the slideshow work, when all articles have an image.
    And for articles view, some categories works, other not (try NHL for example, or Equipes Nationales). And I have create it in the same way.
    (I’ve a megamenu issue, but I will open an other thread)
    Thanks for your help !
    Pierre
    Nazario A Friend
    #521338
    Hi Pierre,
    1/ Article view
    I tried to click on an article link then I saw it’s showing fine now. Have you sorted this out?
    Please make sure that you add image via Images and Links parameter in the settings of article: http://prntscr.com/2pq4h9
    stpere Friend
    #521518
    <em>@Nazario A 409617 wrote:</em><blockquote>Hi Pierre,
    1/ Article view
    Please make sure that you add image via Images and Links parameter in the settings of article: http://prntscr.com/2pq4h9</blockquote>
    Hello !
    1/ No change for me (and your link doesn’t work ). Try to use : http://www.passionhockey.com/site_final/201401285469/Equipes-Nationales/analyse-de-leffectif-suisse-pour-les-jo.html
    We don’t see the article.
    Same issue for some categories like NHL or Ligue Magnus
    http://www.passionhockey.com/site_final/NHL/
    http://www.passionhockey.com/site_final/Ligue-Magnus/
    2/ Ok for the slideshow
    Pierre
    Nazario A Friend
    #522134
    Hi Pierre,
    I have reported your issue to our Dev team, they will check and fix it soon. You can follow the status at: http://pm.joomlart.com/browse/JATCFUBIX-221
    Nazario A Friend
    #522313
    Hi Pierre,
    With help from our dev team, I figured out that the error comes from the sh404SEF component, not our template. I tried to disable it, your site will work fine. You can raise this issue in here, they will help you more.
    1. sh404-1
    2. sh404
    stpere Friend
    #522552
    I really need sh404SEF… I will spoke with them soon.
    EDIT: It seems it comes from a incorrect ID taken by sh404SEF, in progress to correct it
    Since your message, I couldn’t see the slideshow/slidenews blocks on homepage. Do you have changed something in the backoffice?
    Nazario A Friend
    #522677
    @stpere,
    I just fixed that issue by adding below line of code into this file: /templates/ja_fubix/tpls/blocks/head.php :
    <?php
    * @package T3 Blank
    * @copyright Copyright (C) 2005 - 2012 Open Source Matters, Inc. All rights reserved.
    * @license GNU General Public License version 2 or later; see LICENSE.txt
    defined('_JEXEC') or die;
    JHtml::_('behavior.framework', true);
    Now, your site is working fine.
    stpere Friend
    #522686
    Thanks !
    could you explain your modification? Why the 2 modules doesn’t work before that?
    Pierre
    EDIT : and the presentation of the slideshow have changed (link in blue, size of the block) Do you have change the admin settings?
    Nazario A Friend
    #522695
    Hi Pierre,
    The error comes from the fact that the mootools was not loaded in your site.
    PS. I did not change backend settings.
    stpere Friend
    #523201
    <em>@Nazario A 411285 wrote:</em><blockquote>Hi Pierre,
    PS. I did not change backend settings.</blockquote>
    Ok. Thanks
    Last question: I want to have my category view like in your demo website. but I don’t find any documentation for that. Could you explain how confgure it? Is taht a specific layout? Or CSS style?
    Pierre
    Nazario A Friend
    #523340
    Hi Pierre,
    You need to go to backend >> Menu item >> Page Display then add class suffix ” blog-layout” and configure Blog layout as this image:
    Also, you need to create readmore and add intro image for each article.
    Let me know if this helps
    1. fubix8
    2. fubix7
    stpere Friend
    #523445
    I close this post. Thanks
    Pierre
This topic contains 15 replies, has 2 voices, and was last updated by  stpere 10 years, 9 months ago.
