February 26, 2011 at 1:47 pm #160729
My slideshow doesn’t appear anymore on my homepage, I don’t know what exactly happened but it gives an error ID Module XML data non available, could anyone look at this because I don’t know what just happened?!
Question two, a little one is….
Joomla 1.6 now has a JA extensions manager, with this you can update the joomla template or…? In my ja extensionsmanager it says Sorry, no version uploaded in Repository
[Upload Now], what must I upload there or what does this mean? The manager is just there for updating the template etc. isn’t it or…? I want that to work, could you explain me how…?Sherlock FriendSherlock
- 2478 times in 2162 posts
February 28, 2011 at 9:03 am #378795Dear zoutmedia,
Just try to install the slideshow module again,Hope that it help solve the issue.
Regarding the issue of the extensionsmanager extension you can go to Services Manager section, select the Service Name to JoomlArt Updates and enter your account at joomlart.I hope these would help !
1 user says Thank You to Sherlock for this useful post
February 28, 2011 at 1:59 pm #378876I fixed it with the extensionsmanager extension but when I update I get this alert:
Errors occured during upgrading, please fix them fist
Mysql path is not configed
Mysql Dump path is not configed
Local repository path is not configedWhat do I need to do now? And this ja_extensionsmanager, when this works well I just simply click on the button update and the manager updates my complete site? And all the content I have then stays as it was, so no difficult migration things I need to do?
Answer to question before this one about the slideshow:
The slideshow problem is fixed, I discovered I got an old version of cyberduck ftp programm and because of that he blocked the slideshow. I do walk against another problem with the slideshow and that is when I click on SAVE in the module slideshow it says “NO PERMISSION”, my ftp permissions are set allright so that’s not it, what to do…? >> answer found here http://www.joomlart.com/forums/topic/ja_slideshow-on-joomla-1-6/March 2, 2011 at 7:07 pm #379332Anyone…?
March 3, 2011 at 2:15 am #379348Dear zoutmedia,
To fix the issue of the ja_extensionsmanager you need to go to components >> Ja extension manager ,here click on the Configuration panel you would see the input texts for you to set Mysql path,Mysql Dump path and Local repository path.
I Hope that help.
March 8, 2011 at 10:40 am #380265Okay, I asked my provider to send me the mysql path, mysql dump path and local but I don’t think they have them because the first time they answered me they send a .phpinfo but it was not in there. Where can I find this info…?
This topic contains 6 replies, has 2 voices, and was last updated by zoutmedia 13 years, 9 months ago.
