  • Rob Hawthorn Friend
    #141796
    The jaslideshow module gets stuck on the second image if the thumbnails are off.
    This is the same as another thread but no one’s got any advice. Any advice is much appreciated.
    Regards,
    Rob
    Anonymous Moderator
    #307405
    Hi rob_hawthorn
    I have tried to login to your admin to check your issue but could not.
    The account which you provided is not correct.
    Please kindly check again
    Rob Hawthorn Friend
    #307422
    <em>@JA Developer 132083 wrote:</em><blockquote>Hi rob_hawthorn
    Please kindly check again</blockquote>
    Hi, sorry about that I’ve correct the credentials (and send a message), thanks
    budge Friend
    #307896
    <em>@rob_hawthorn 132101 wrote:</em><blockquote>Hi, sorry about that I’ve correct the credentials (and send a message), thanks</blockquote>
    Was your problem solved Rob?
    Rob Hawthorn Friend
    #307945
    Hi budge, the solution worked, got it sorted last night. See the following:
    + Open templates/ja_zinc/js/ja.script.js file, at about line 348, find following code section:
    var fxOptions = {duration:JaSlideshow.options.duration[0], wait:false}
    var thumb1 = $(‘jsnav’+current[2]);
    thumb1fx = new Fx.Style (thumb1, ‘opacity’, fxOptions);
    thumb1fx.start (inactive_opacity);
    var thumb2 = $(‘jsnav’+current[0]);
    thumb2fx = new Fx.Style (thumb2, ‘opacity’, fxOptions);
    thumb2fx.start (1);
    and change to:
    if ($chk(thumb1))
    if ($chk(thumb2))
    thumb2fx.start (1);
    budge Friend
    #307974
    Rob, your a legened mate. Works a treat.
This topic contains 6 replies, has 3 voices, and was last updated by  budge 15 years, 6 months ago.
