  • mountainman Friend
    #169394
    On my site the slideshow fades in and out.
    I thought I would try making it slide from left to right. There are 6 images in the show.
    When the first image is shown the appearance is correct. The image is placed appropriately in its space.
    For all the other image the space is enlarged toward the left by, perhaps, 10px and reveals part of the previous slide. Presumably this is not a problem for the first slide because the first slide is the leftmost slide in the series.
    What needs to be done to prevent this happening? The space is defined by parameters set in the module item page.
    Thanks for any help.
    TD
    jooservices Friend
    #417412
    Because i’ve no see any slideshow on your site.
    Would you mind give me a page URL and a screenshot for explain ?
    Thank you
    Viet Vu
    mountainman Friend
    #417449
    addacumen.com/armt3/
    Screenshot of top right of screen attached.
    1. slideshow
    jooservices Friend
    #417486
    Thank you, I’m checking this for you!
    jooservices Friend
    #417495
    You try fixing it as following:
    Open file css/template.css
    Add this code to bottom:
    ja-slide-main-wrap{
    left: 15px;
    .ja-slide-main {
    margin-left: none !important;
    Viet Vu
This topic contains 5 replies, has 2 voices, and was last updated by  jooservices 13 years, 3 months ago.
