  • Saguaros Moderator
    #966936
    @kugelmeier
    You can update the URL and login info of your site, I will have a look.
    kugelmeier Friend
    #966968
    ..I have given the infos of the side.
    kugelmeier Friend
    #967008
    ..and I have another problem with contact. Why is the position from contact wrong?
    Klaus
    1. screen
    Hi Klaus,
    For the slideshow, try to use the markup as I applied for the 2nd item in the slideshow: http://prntscr.com/cgyjry
    With the contact form, seems that you already changed it, is that ok now?
    kugelmeier Friend
    #967555
    …I had only deactive the contac, now its like I posted the issue.
    What is the reason for it?
    Thanks for the slideshow, now its ok.
    Regards Klaus
    I just re-configured the contact under Contact Component on your site, you can see it looks like demo site now.
    kugelmeier Friend
    #967582
    ..ok, it needs the with without the side menue.
    Thanks, I can live with it.
    Klaus
This topic contains 7 replies, has 2 voices, and was last updated by  kugelmeier 8 years, 3 months ago.
The topic ‘Slideshow problem with text’ is closed to new replies.
