imported_lorenzoadorni Friend
- May 2015
October 2, 2017 at 9:14 am #1065271Hello,
There is two problem with the thumb of the slideshow.
1- Image display is not scale and centered in the thumb.
2- Thumb is gone up and overlying slideshow.
Here url: http://www.maximal.it/nuovosito/index.php?lang=it
Here code in the custom css for slideshow:
/ SLIDESHOW /
.slideshow .has-mask::before {
background-color: rgba(0,0,0,0)!important;
background-image: none;
background-position: left bottom;
background-repeat: no-repeat; content: "";
position: absolute;
top: 0;
left: 0;
height: 100%;
width: 100%;
}/ SLIDESHOW – MARGIN TOP /
.t3-mainnav + div.t3-masthead, .t3-mainnav + div.t3-slideshow {
margin-top: -32px;
}/ SLIDESHOW – PRESENTAZIONE MINI SLIDE IN BASSO – VIDEO /
.video-intro {
display: none;
}.slider-content-inner {
color: #000000!important;
}.slider-content-inner .item-desc{
}/ SLIDESHOW – VISUALIZZAZIONE THUMB /
.slideshow .swiper-thumbs-wraper {
display: none;
/Here all the custom css code:
/ CONTATTI RAPIDI DESTRA LOGO ALLINEATI SU LINEA SOLA /
@media (min-width: 768px)
.address-list li {
float: left;
width: 21.333333%!important;
}}/ BLOCCO CUSTOM CONTATTI HEADER /
.custom_contatti
padding-top: 10px!important;
padding-bottom: 0px!important;
}/ MAIN MENU ORIZZONTALE /
.t3-mainnav .t3-navbar {
background: linear-gradient(#FFFFFF,#FFFFFF);
max-height: 84px;
padding-bottom: 120px;
}.navbar-default .navbar-nav > li > a, .navbar-default .navbar-nav > li > span {
font-size: 12px;}
.navbar-default .navbar-nav>li+li:before {display:none;}
.navbar-default .navbar-nav>li>a, .navbar-default .navbar-nav>li>span {
color: rgba(160,163,164,1);
}.navbar-default .navbar-nav>li>a, .navbar-default .navbar-nav>li>span {
}/ MAIN MENU ORIZZONTALE – COLORE ATTIVO E COLORE HOVER /
.navbar-default .navbar-nav>.active>a, .navbar-default .navbar-nav>.active>span, .navbar-default .navbar-nav>.active>a:hover, .navbar-default .navbar-nav>.active>span:hover, .navbar-default .navbar-nav>.active>a:focus, .navbar-default .navbar-nav>.active>span:focus {
color: #2b5071;
background-color: transparent;
}.navbar-default .navbar-nav>li>a:hover, .navbar-default .navbar-nav>li>span:hover, .navbar-default .navbar-nav>li>a:focus, .navbar-default .navbar-nav>li>span:focus {
color: #2b5071;
}/ SLIDESHOW /
position: absolute;
top: 0;
left: 0;
height: 100%;
width: 100%;
margin-top: -32px;
.video-intro {
display: none;
display: none;
// BLOCCO PRESENTAZIONE MAXIMAL /
.acm-features{
padding-top: 40px!important;
padding-bottom: 40px!important;
}/ BLOCCO CUSTOM PRESETNAZIONE EVOLUCI /
.custom_evoluci
padding-top: 0px!important;
margin-top: 00px!important;
margin-bottom: 0px!important;
}/CALL TO ACTION/
.acm-cta
margin-top:0px!important;
margin-bottom:0px!important;
}/ BLOCCO CUSTOM EVODIGITAL /
.custom_evodigital
margin-top: 50px!important;
margin-bottom: 50px!important;
}/IMPOSTAZIONI BREADCRUMB/
.breadcrumb
margin-left: 0px!important;
margin-top: 5px!important;
}/ IMPOSTAZIONE PADDING GENERALI /
.section-wrap>div {
padding-bottom: 40px;
padding-top: 40px;/
.evo_verde {
background: #cccc33
/ PERSONALIZZAZIONE BOTTONE CALL TO ACTION, DA REPLICARE PER OGNI STILE DIVERSO E DA RICHIAMARE NEL SUFFIX STYLE DEL MODULO /
.btn-default {
background-color: #3a5d80;
border-color: #3a5d80;
color: #fff;
background: linear-gradient(#426a92,#3a5d80);
border: 0;
font-size: 11px;
font-family: "Rubik",Helvetica,Arial,sans-serif;
text-transform: uppercase;}
/ IMPOSTAZIONE COLORE SFONDO DEL FOOTER/
.t3-footer {
background: #F3F3F3;
color: #aaa;
.t3-footnav .t3-module {
color: #aaa;
.box-contact .contact-item {
border-radius: 2px;
*//PADDING LOGO/
.logo {padding-left: 15px;
*// PADDING HEADER /
.t3-header {
padding-top: 32px;
/PADDING CASO STUDIO/
.acm-testimonial
margin-top: 10px!important;
margin-bottom: 60px!important;
Attached you can find an image of the problem for the first slide
Thank you
October 3, 2017 at 1:38 am #1065382Hi
Kindly turn off css compression and server page speed compression so i can check the custom.css file
Or you can temp. remove the file to see the slideshow.Regards
imported_lorenzoadorni Friendimported_lorenzoadorni
- May 2015
October 3, 2017 at 7:10 am #1065455I think the problem is that I use a 1600 X 500 px image instead a 166 X 800.
There is any code to have the thumb not overlying slideshow, or also less overlying ?
October 3, 2017 at 7:21 am #1065459You can share a screenshot and illustrate the request in it how you want to display the thumb over the slideshow.
I will check it.Regards
- May 2015
October 3, 2017 at 8:22 pm #1065560Here Image
As you can see in thumb, image is not fit in the right way in the thumb box.
Is distorcedimported_lorenzoadorni Friendimported_lorenzoadorni
- May 2015
October 3, 2017 at 8:41 pm #1065563This Image should be more clear
As you can see
1 – there is a code to enlarge the image size to fit the box? How you can see to the right there is a orange area that is usless
2- there is code to set the size of the thumb box?
3- the image in the box is distorced. How can I solve?
October 4, 2017 at 2:02 am #1065611Hi
In the thumbnail, it show the title and thumbnail in this way.The image is resized and using 100% width
http://prntscr.com/gszgxj
You can add below code in custom.css file set image height auto in thumbnail.slideshow .swiper-thumbs-wraper .swiper-thumbs .item-image { float: right; max-width: 100%; height: auto; }
If you still looking for more customization in the slideshow style, I suggest you to use firebug or inspect element to check the style classes and override it in custom.css file.
- May 2015
October 4, 2017 at 7:23 am #1065690The problem is that the image is not just scale in box but adapted and distorced.
Still many problem with this. I think is better just switch off thumb.
Can I just display the arrow of navigation without display all the thumb?
Thank’s
- This reply was modified 7 years, 2 months ago by imported_lorenzoadorni.
October 4, 2017 at 7:47 am #1065710Hi
You can use this code.slideshow .swiper-thumbs-wraper .swiper-wrapper { display: none; } .slideshow .swiper-thumbs-wraper .swiper-button-white { margin-top: -136px;}
Change margin-top value as per needs.
- May 2015
October 4, 2017 at 7:02 pm #1065911No arrows display visible…
October 4, 2017 at 11:57 pm #1065945Hi
Replace older code with this code.swiper-container.slideshow-thumbs {display:none!important;} .swiper-thumbs-wraper.swiper-button-white { margin-top: -236px!important;}
- May 2015
October 5, 2017 at 7:33 am #1066028Seems no work. Nothing happened.
October 5, 2017 at 8:20 am #1066041Hi
Disable the css compression so i can check,Regards
AuthorPostsViewing 13 posts - 1 through 13 (of 13 total)This topic contains 12 replies, has 2 voices, and was last updated by Pankaj Sharma 7 years, 2 months ago.
