imported_lorenzoadorni Friend
- May 2015
October 23, 2017 at 2:58 pm #1069598As you can see in a responsive situations happend this:
- button of the slide disappear
- the "get a quote" button go down
How can a I resolve?
Saguaros ModeratorSaguaros
October 24, 2017 at 4:17 am #1069702This reply has been marked as private.imported_lorenzoadorni Friendimported_lorenzoadorni
- May 2015
October 31, 2017 at 12:34 pm #1071355Sorry,
http://www.maximal.it/home/ is the oldest website that i’m going to change with the new joomlart template.
So you can find here: http://www.maximal.it/it/
Thank’s
November 1, 2017 at 8:47 am #1071556Hi,
I check your site in my iPhone device but the ‘get a quote’ button doesn’t go down. Kindly check again.
For the button in slideshow, it’s re-styled in mobile view. If you want to show the same way as desktop view, you can open the file:
root/templates/ja_company/acm/slideshow/less/style.less
At approx line 82, remove this declaration:
// Mobile view @media (max-width: @screen-xs-max) { background: transparent; border-bottom: 1px solid @brand-secondary; border-radius: 0; color: @white; padding: 0; &:hover,&:focus,&:active { color: @brand-secondary; } }
Once done, you need to compile less to css (there is a button LESS to CSS in template manager). Remember to backup all CSS files first as when compiling less to css, they will be overridden.
- May 2015
November 1, 2017 at 11:38 am #1071604When I click to compile LESS, there is an error:
Errore
parse error: failed at
&:extend(.clearfix all);
/home/eartspac/domains/maximal.it/templates/ja_company//acm/slideshow/less/../../../less/../../../plugins/system/t3/base-bs3/bootstrap/less/mixins/grid.less on line 11
Si รจ verificato un errore. Compilazione fallita.Saguaros ModeratorSaguaros
November 1, 2017 at 4:00 pm #1071689You can take a backup of your site and share the FTP account so I can check.
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 2 voices, and was last updated by Saguaros 7 years, 1 month ago.
Slideshow Responsive problem
