  • mamsadegh Friend
    #731798
    Hi.
    I am using Ja Techzone and slideshow inside it.
    I want each slide to have a button on it, so that the user can click on the button and go to the respective page for that slide.
    In slide show settings,
    I put “Current Position” to “Top Right”
    but the button appears on the top left side of the slide show.
    I mean, only top left works, and not top right.
    why is this happening?
    Thanks.
    mamsadegh Friend
    #752723
    Just a small notice that i am still waiting for a reply on this.
    since it doesnt really work.
    you know overal, i am really getting disappointed with joomla. i feel it is waste of time. It just can’t handle user requirements. every time you want to make a small change in something, you end up asking an expert to change the source code of some where in your web site to magically fix the things.
    Ninja Lead Moderator
    #752778
    I checked with Content Position: Top Right and saw it’s working fine
    You can pm me the URL of your site and admin login, I will help you to check it
This topic contains 3 replies, has 2 voices, and was last updated by  Ninja Lead 9 years, 2 months ago.
