  • adams62 Friend
    #155005
    I set the JA Droid template direction to RTL, Slideshow2 not show
    you can see this problem in http://www.joomlart.com/demo/#templates.joomlart.com/ja_droid please Change To RTL
    please help me
    I use FireFox & IE 8.
    Hello
    Thanks for reporting, i have created an issue on JA Project Manager for download update.
    Here is a quick fix for your module
    you add the following css into the template.css file:
    .ja-slide-main {
    left:0;
    top:0
    when the bug is fixed & updated on the download package, i will keep you informed.
    adams62 Friend
    #358196
    Thank you very much. That worked … Thanks For Answer 🙂
This topic contains 3 replies, has 2 voices, and was last updated by  adams62 14 years, 1 month ago.
