  • janko67 Friend
    #176174
    Hi there,
    as per subject, I have some problems with slideshow module in droid template.
    It does not authomatically slide the images. It loads the images randomly, but they remain still even if the auto play is set to yes. I hae tried to toggle settings in many ways, but nothing changed.
    Any suggestion?
    Blaine Friend
    #448491
    Please tell me the version of Joomla and the latest number of the template you have installed.
    janko67 Friend
    #448493
    Joomla 2.5.4
    as for the templates, the site templates installed, included the default joomla installation ones, are 14.
    the doid template version is 2.5.0 (date february 2012). Should be the last update.
    Do you need further details?
    Thanks for your help
    Blaine Friend
    #448581
    Have you used JA Extension Manager or checked in the downloads section of JA to be sure all is up to date?
    janko67 Friend
    #448700
    yes, I have checked trough the extension manager, and I have olso tried to download the complete template again yesterday, uninstalling the slideshow module and reinstalling it, but I have the same problem.
    May you point me to the latest module release in order to compare it with the one installed?
    Any other thoughts?
    Blaine Friend
    #449043
    Please renew your membership in order to see the latest version released. I would also suggest you make sure you have it set to scroll automatically in the settings.
This topic contains 6 replies, has 2 voices, and was last updated by  Blaine 12 years, 7 months ago.
