  • rbranden Friend
    #151003
    I am using the mod_jaslideshow2 with JA_Kyanite_II
    I have navigation set to Vertical Right yet the navigation is on the left
    See http://www.gocubamo.com/hub1/
    sunrise Friend
    #343304
    Hi rbranden,
    I don’t know, but could it be something with the cache. Does it show on the right if you try a different browser?
    rbranden Friend
    #343351
    Thanks for the reply Sunrise
    No it shows the same in all browsers tested.
    ie
    mozilla
    opera
    crome
    rbranden Friend
    #343352
    is there a piece of css that controls this?
    Dear rbranden!
    Please get this file /ja_rasite/css/mod_jaslideshow2.css file from the ja rasite package and put it’ into your template
    Good luck
    rbranden Friend
    #343428
    Still a couple of glitches to work out. The arrow is not showing and the description coloring takes uses the whole page now..
    I can work with those and let you know how it goes.
    THANKS tienhc
    Rob
This topic contains 6 replies, has 3 voices, and was last updated by  rbranden 14 years, 7 months ago.
