  • rwillmore Friend
    #117611
    Hi, thanks for your great templates. I am using JA Pollux with the Collapsed Module plugin, and unfortunately, when the modules are collapsed, there is often some text peeking through the bottom of the module. Is there an easy way to hide this text automatically?
    Please see the attached picture for an illustration of the problem.
    Thanks!
    1. 2006-11-10_185716
    ha le-viet Developer
    #211578
    Hi offtheguide,
    Please input the offset parameter for this module. It was showed in the ReadMe topic or in the documentation you can download.
    Regards,
    Ha Le-Viet.
    P/S: Thread moved to JA Pollux area.
    #211579
    Thanks, I forgot to do that on template re-install. :-[
    I will point out to other users of collapsed modules (great plugin) that you will need the menu title to be shown (choose “show title” for the corresponding menu in module manager) in order for the collapsed modules plugin to work correctly. If you have the menu title hidden, the first link will appear where the title normally would, and you will be unable to collapse the module. See the attached image for illustration.
    Thanks again!
    1. 2006-11-11_005253
This topic contains 3 replies, has 2 voices, and was last updated by  ha le-viet 18 years, 2 months ago.
