I just notice that the PREV and NEXT buttons of K2 item page aren’t “JText”, so it not change with the translation .ini file.
Here is the solution:
Go to templates/ja_pyro/html/com_k2/item.php around line 482 change the PREV and NEXT to your language.
[PHP]<?php if(isset($this->item->previousLink)): ?>
<a class=”itemPrevious” href=”<?php echo $this->item->previousLink; ?>” title=”<?php echo $this->item->previousTitle; ?>” >
« Prev
</a>
<?php endif; ?>
<?php if(isset($this->item->nextLink)): ?>
<a class=”itemNext” href=”<?php echo $this->item->nextLink; ?>” title=”<?php echo $this->item->nextTitle; ?>” >
Next »
</a>
<?php endif; ?>
[/PHP]
Or, use the original K2 sentence, instead of the NEXT or PREVIOUS, it uses the next or previous articles titles, remove the original sentence and use this:
<a class=”itemPrevious” href=”<?php echo $this->item->previousLink; ?>”>
« <?php echo $this->item->previousTitle; ?>
</a>
<?php endif; ?>
<a class=”itemNext” href=”<?php echo $this->item->nextLink; ?>”>
<?php echo $this->item->nextTitle; ?> »
</a>
<?php endif; ?>[/PHP]
Small thing, but annoying if it’s on another language. Maybe should be corrected for next release? insert as JText at least!
