dpchap015 Friend
dpchap015
- September 2011
- 24 times in 1 posts
April 21, 2014 at 6:46 am #196942Hi..
I faced an issue because of smart search component. Smart search creates a Table in the database > Finder_termsOn my site the total size of the Database is 275 MB .
And the Finder_terms table size is 215MB .
This issue is related to the joomla, because its a default joomla extension.
But As i can see this extension feature is Recommended by JA In all Of the templates like JA Magz .
.I hope there must be some tweak to restrict the size of this Table .
Thanks in advance
alexsmirnov Friendalexsmirnov
- July 2012
- 163 times in 119 posts
April 21, 2014 at 3:02 pm #531781Hi,
Actually, Smart Search creates more than one table:
To find best ways to manage your resources while running this plug-in please read:
– Smart Search quickstart guide
– Smart Search Frequently Asked Questions
You may also wish to study these Smart Search user cases.
Hope this helps.
Regards.
Alex
dpchap015 Frienddpchap015
- September 2011
April 21, 2014 at 3:18 pm #531783<em>@alexsmirnov 422860 wrote:</em><blockquote>Hi,
Hope this helps.
Regards.
Alex</blockquote> @alexsmirnov Please don`t change the thread prefix without solved it 🙂
I already went through the links that you mentioned above .
I know that smart search create more then one table .I mentioned the finder_terms table because its the only table that contain huge amount of data and make the DB heavy .
thanks for reply .I will wait for some one from support team to give solution on this problem. 🙂
Nazario A FriendNazario A
- April 2013
- 284 times in 263 posts
April 28, 2014 at 10:14 am #532678@ dpchap015,
You can just clear the index of that search here: Components -> Searchindex -> Delete index
And all the tables will be empty, you should turn it off afterwards: Extensions -> Plugins -> Choose type “finder” -> Disable all the finder-plugins
It´s used for the search suggestions with the smart search module. It won´t work with an empty index. as long as it´s active it will continue to index new content on your website and write those huge tables in your database.
Hope this helps.
- September 2011
April 28, 2014 at 11:48 am #532698<em>@Nazario A 424009 wrote:</em><blockquote>@ dpchap015,
Hope this helps.</blockquote>
HI @nazario A if disabled the plugin it means that the smart search will not work anymore .
This is not the solution , you are telling me to disable the useful component .
As you know the smart search is recommended by the Joomlart in all the templates , so please provide the solution .please read my first post again
Hope you understand what i am saying .how to fix this problem?
Saguaros ModeratorSaguaros
April 29, 2014 at 4:17 am #532812I understand your concern but you’re not only the person who face this problem when using this com_finder. You can make a search in Joomla forum and see some threads discussing about the same topic.
We recommend this smart search in our templates because it generates fast and accurate results in searching. However, in order to have such great search results, it creates a complete index of your site all the time which will take the storage.
If you’re worrying about the storage rather than the fast searching the smart search has, you can disable it (as Nazario suggested). Should you care more about the storage, please consider to use the old search of Joomla which is not efficient and as a result, it won’t take any space in your server.
I believe you know this finder is default component of Joomla, we often override layout/style default exts from Joomla, we don’t change their core function, all concern/fixes for them you can raise/find in Joomla community.
Best,
- 1334 times in 848 posts
April 29, 2014 at 6:04 am #532826How is this issue related to Joomlart templates? Please limit your questions to bugs of the template only, we are not obliged to provide support for Joomla. You know it well that its a default Joomla extension, and our template has nothing to do with it. Please do not overload support with Non-JA questions.
and i recommend you to upgrade to JA Developer account if you are using personal account for developing sites for clients.
Arvind
4 users say Thank You to Arvind Chauhan for this useful post
- September 2011
May 9, 2014 at 11:51 am #534358@drarvindc: I am sad to see such a reply form such highly reputed member form JA.
Unfortunately we are Global Education Technology Community and web media platform delivering top quality education technology news and research to over 170 countries and territories. We are not web developers as you think just because we post queries.If you can offer help/solution i would really appreciate if you can stop posting unacceptable replies
<blockquote> Please do not overload support with Non-JA questions.and i recommend you to upgrade to JA Developer account if you are using personal account for developing sites for clients. </blockquote>
I hope this makes sense to you.
Regards.
- July 2012
May 9, 2014 at 12:52 pm #534361Hi there,
It’s nice to see you mentioning making sense because the following does make full sense:
<em>@dpchap015 422786 wrote:</em><blockquote>
…This issue is related to the joomla, because its a default joomla extension.
</blockquote>And, with due respect, holding JA accountable for how Joomla core stuff work or doesn’t work doesn’t make sense whatsoever.
… i can see this extension feature is Recommended by JA In all Of the templates like JA Magz .
</blockquote>– doesn’t make sense. Please produce a solid proof where JA uses Joomla “Smart Search” in it’s advertising or pre-sales materials and I promise to eat my hat.
Regards,
Alex
1 user says Thank You to alexsmirnov for this useful post
- September 2011
May 12, 2014 at 9:25 am #534609<em>@alexsmirnov 426240 wrote:</em><blockquote>Hi there,
Regards,
Alex</blockquote>
My dear friend Alex, anything that you guys supply with your Quick Deployment Package – The so called “kickstart”; is your responsibility as i am using the same package.
So please stop covering things with quotes that make sense to you and which don’t.BTW, its your package with your template that has something called “Smart Search” and since you guys are providing it to me which is always enabled with a dedicated menu for it.
I am not here to fight with you for your baseless explanations (which was not expected and required). Only reply if you have solution to the issue.
May 16, 2014 at 4:52 am #535390dpchap,
We are not going to support anything beyond our own product. Lets be clear on that.
I have replied to you earlier also on the same topic. JA product support only and be polite to the mods here. I do not think asking mods to reply only if they have the answer you want is going to help you.
Read my earlier reply again and expect JA product support only. We would not provide support for Joomla! or 3rd party products.
Arvind
1 user says Thank You to Arvind Chauhan for this useful post
AuthorPostsViewing 11 posts - 1 through 11 (of 11 total)This topic contains 11 replies, has 5 voices, and was last updated by Arvind Chauhan 10 years, 6 months ago.
