amir00251 Friend
amir00251
- January 2011
- 11 times in 1 posts
September 29, 2011 at 1:16 am #169250I have just installed Ja Voice, Every thing works fine apart from commenting system.
In Ja Voice, I have set Ja commnet as default, all ja commnet system plugins are enabled, ja comment works fine with all other extensions but in JA voice, when I click on the commment(0),
I get a blank content with “no item”.
I appreciate someone to let me know if I am doing somthing wrong?
Blaine FriendBlaine
- August 2007
- 177 times in 154 posts
September 29, 2011 at 4:20 am #415597Hi Amir00251!
What version of Ja Voice are you using and what version of Joomla?
Thanks!amir00251 Friendamir00251
- January 2011
September 29, 2011 at 9:58 am #415642Hello, I have installed latest JA voice 1.0.0 on Joomla 1.6.6.
I have also latest version of Ja Comment working with no problem with other extensions.
Blaine FriendBlaine
- August 2007
September 29, 2011 at 9:55 pm #415742Hi amir00251!
Please be so kind as to provide me a link to the site.
- January 2011
September 30, 2011 at 2:24 pm #415886Hello, I have sent the logging details by message.
Blaine FriendBlaine
- August 2007
October 3, 2011 at 1:38 am #416320HI amir!
Do upgrade to Joomla 1.7 at this time. There should be no reason not to if you are using 1.6 currently.
I turned on JA Voice in your site, maybe it will work now.
Also, there are many items checked out, please be sure to check items in after editing.
- January 2011
October 3, 2011 at 9:30 pm #416559Hello, Could you be please more constructive than this.
I had already set the ja voice and ja comment plugins, and basically I dont think that you did do anything. The problem still exists.
I need a more detailed look at the problem as every thing else works fine and I dont have any other option.
I dont want to use external commenting systems such as Echo, etc
Also Jomcomment and Jcomment are not compatible yet with Joomla 1.6.
I have a complicated site which is not going to be upgraded to 1.7. I look forward to your respond. Thank you.
Blaine FriendBlaine
- August 2007
October 3, 2011 at 10:18 pm #416574Well Amir,
The item Ja Voice was not published when i went to your site, so I published it.
I will ask another mod to step in on this for you Amir.amir00251 Friendamir00251
- January 2011
October 3, 2011 at 10:52 pm #416581Thank you, there may be a small hack in code needed.
- January 2011
October 3, 2011 at 11:15 pm #416585Hello, I have solved the problem.
It was the same issue as
http://pm.joomlart.com/browse/JAVOICE-402
If this issue has not been considered in latest version of ja voice, should be changed in latest release.
- January 2011
October 3, 2011 at 11:28 pm #416587Sorry, it seems that the problem is not resolved with the code hack proposed in the above link.
Problem certainly is the “Search Engine Friendly URLs” becaue it is resolved when you turn this off.
Could your developers have a look at this please?
Blaine FriendBlaine
- August 2007
October 4, 2011 at 1:17 am #416605Amir,
I am glad the issue is solved!AuthorPostsViewing 12 posts - 1 through 12 (of 12 total)This topic contains 12 replies, has 2 voices, and was last updated by Blaine 13 years, 2 months ago.
**SOLVED** Ja Voice commenting system problem
